Why I'm not able to redraw a line?
Postby Nowhk » Wed Nov 11, 2015 4:57 pm
This is the situation I have:
I'd like to redraw the line (i.e. its height) every time I tweak the knob.
I can see the value change using "watch", but the line is not redraft. Where am I wrong?
Hope you can help me.
Thanks for your time, as usual!
Nowhk
Re: Why I'm not able to redraw a line?
Postby tulamide » Wed Nov 11, 2015 5:06 pm
All inputs you name are automatically converted to an instance variable. So your input "height" is also available as @height. But you also declare another variable as @height. Rename one of them.
Postby Nowhk » Wed Nov 11, 2015 5:08 pm
tulamide wrote:All inputs you name are automatically converted to an instance variable. So your input "height" is also available as @height. But you also declare another variable as @height. Rename one of them.
Uhm, nothing change :(
moving knob, I can't see any redraft....
Nowhk
Postby Nowhk » Wed Nov 11, 2015 5:14 pm
Oh no wait, it works! Just I can't see move it in the preview in the top! Thanks ;)
Nowhk
