need some little help auto volume tool
Im trying to make a tool there u put on Mixer track and it become 0 db volume when its on. And then u can change from 0 db to - 0.5. any ideas pls?
- djbrynte
Re: need some little help auto volume tool
Yep-
get bootsy's 'fast RMS', and put 1 over the level figure coming out,
then multiply the original signal with that. Then multiply the normalized figure by .5 to get half of normalized.
RMS is - root mean square, which is the amplitude/loudness average.
You need to delay the original signal by the RMS window, to process the correct block
