How to connect 2 computers digitally w. Flowstone?
Postby mayo » Sun May 23, 2021 12:25 pm
Hello
How to connect 2 computers digitally and use 2nd computer as external hardware effect please?
I mean one computer is main music station, 2nd small touchscreen computer is running Flowstone made standalone application as external effect in chain.
2 soundcards with s/pdif ? (or usb / lan connection would be even better)
Highest sound quality (no lose of quality, jitter etc.) is needed that is why digitall connection is needed, not analog because of adda conversion loss of quality.
Thank you very much
mayo
Re: How to connect 2 computers digitally w. Flowstone?
Postby aronb » Wed Jul 07, 2021 5:06 pm
I was hoping someone may have done this before in Audio with the "Audio Stream In Module".
Check out this module, it can capture Audio from a remote location, then your second machine can process and play it.
StreamIn_Module
I have done this with Video. I get an image from a Webcam, scale it, add an overlay, then have a Ruby module find the outer dimensions of an object, the "bounding Box", (basically to the CCD size x the lens magnification and my edge detection algorithm - works well ;) ). One computer transmits the image to an IP address, then I get the data on another machine. The frame rate is about 20Hz, not the best but for me it is fine.
Aron
aronb
Postby mayo » Mon Aug 09, 2021 11:58 am
aronb wrote:Hi,
Aron
Thank you very much, interesting idea. But how can I make/establish that one computer transmits sound to IP address please? (what exactly I should do?) and what to add as source file or location input - that Ip address ?
Thanks a lot for info.
mayo
Return to DSP
