FlowStone 3.0.9 Beta1
Re: FlowStone 3.0.9 Beta1
Ooops - overlooked this bug:
One grid is missing vertical on the right Border and horiz. at the bottom in Focus Mode and on the right in EXE's
- FS v309b1 bug EXE R-1Grid.png (46.23 KiB) Viewed 22711 times
hehehe, funny thing... we noticed it too, and are already investigating
MyCo - Posts: 718
dunno if it's related with this beta:
after a crash (could not reproduce it now) a left over recovery file let all double clicked .FSM again crashes on load...
Loaded via FS all was fine... after deleting buggy *(recovered)pid=nnn.fsm => all normal again
MyCo wrote:Another option (which is actually easier to handle) would be like this:
1. open Regedit and export the key HKEY_CURRENT_USER\Software\DSPRobotics\FlowStone to some file
2. install 3.0.9 to a different program directory (so you don't overwrite the old version)
3. open Regedit and export the key HKEY_CURRENT_USER\Software\DSPRobotics\FlowStone to some other file
To switch versions you just double click on the corresponding regedit export file.
I chose this option, however after switching to 3.0.9 and back to 3.0.8 I get this:Please help!
I really appreciate the beta and generally support the approach. However, next time please provide a proven recipe for use in parallel with last stable FS release.
well, then you probably have the wrong regedit export clicked before switching. It's not that I just made this up... I use that workaround myself
Important part is actually this key:
"HKEY_LOCAL_MACHINE\Software\DSPRobotics\FlowStone\Install Folder"
You might need the right windows user permissions to update the registry, maybe that's the problem. Just check the key if it's pointing to the right directory / check the FS help dialog if you're actually running the right version.
MyCo - Posts: 718
Walter Sommerfeld wrote:dunno if it's related with this beta:
I get that sometimes in 3.08.1
MyCo wrote:well, then you probably have the wrong regedit export clicked before switching. It's not that I just made this up... I use that workaround myself![]()
Thanks, MyCo. It does not work for me, though.
Maybe you'll have to use this key:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\DSPRobotics\FlowStone
MyCo - Posts: 718
Bingo! It's there! And there is one Install Folder specified, which is the FS 3.0.8 folder. That explains it. So how do I add the FS 3.0.9 Install folder? I did choose a different folder during FS 3.0.9 installation. The 3.0.9 folder has been created, and Flowstone.exe and all the other files are there. Apparently the installer did not create a proper entry in my registry.
