Clock Accuracy - 10ms?
Re: Clock Accuracy - 10ms?
Todays hardware performance is amazing, isnt it?
Yeah man,
FS is sample by sample.
You can get 128k out of it too.
martinvicanek wrote:Todays hardware performance is amazing, isnt it?
Hahah, I don't mean this. I mean that such code:
i = i + speed;
i = i&(i<samples);
processed at different clock (44100hz as you noticed) instead of 48Khz, makes huge differents if I use it for read sample from a Read module (as you suggested). Because it increase the speed of the whole process.
It is not a simple "for statement" that try to iterate in the slower time (more CPU you have, more faster it will be). Its a "for" that must iterate in a fixed time (i.e. sync). Am I right?
nix wrote:Yeah man,
But not every kind of processing inside FS! Ruby code is way more slower.
For what I see, only DSP code get and stay in synch at that speed (and maybe also Assembler code).
- Nowhk
Anyway I think I'm making some other mistakes:
Without rely on Graph (I removed it; could be delayed as suggested), every time an integer in INDEX module is outputted, I should immediatly see the current sample of that index changing in the other SAMPLE module.
Instead they are way (waayy) to async. What am I missing dudes? Its somethings like 3/4 seconds delayed. Too heavy...
can't figure it out!
I guess that:
when i==0 output => -0.693325
when i==1 output => 0.755871
and so on. Instead it "change" around i=1.78 for example, and the first step is quicker than the others (i=1 happens quickly).
I guess that:
- Nowhk
Yep- only streams use samples.
I'll have a peek at your schematic over the weekend
nix wrote:Yep- only streams use samples.
Wow, thanks! You will make me very happy, because I need to made this kind of stuff for the project Ive in my mind. Stay tuned...
- Nowhk
hmm-
can I get the whole LFO schematic?
Do you need to use ppq?
ps- when you use .00001 as the counter iter,
it takes very long to count to 1, which is where it will register an integer step in the wave read
Hey again Nowhk,
I saw your post at Fruity, so I learnt more about the ppq hack.
Here is the counter I have modified->
So the string array and the counter read the same.
Does that help?
http://imageshack.com/a/img633/1214/qJgkVp.png
Does that help?
This might help.
Check the blue section in this modulator. (It's an old 'myco' circuit from way back.)
nix wrote:Hey again Nowhk,
Does that help?
Uhm, I don't understand your schematic: it's identical to mine! And in fact using "i + .00001" I've the same problem.
billv wrote:This might help.
Uhm, not really
- Nowhk
