Quilcom SIM-WINDHARP: The answer my friend is...
Postby Spogg » Sun Aug 22, 2021 9:07 am
This may well be the most niche (i.e. useless) thing I’ve made so far, but I got interested in Aeolian harps so decided to have a go at a simulator which can cover a wide range of variations (of which there are many).
It’s categorised as an effect but it operates a bit like a synth but with no MIDI input, and all processing is in blue and mono4 streams. It does have a sidechain signal input for controlling the wind speed externally. In fact I wasn’t planning on providing that but I couldn’t export it with no inputs present! Don’t tell anyone. ;)
Some folk believe it’s a relaxing sound so I made a stand-alone export too so you don’t need a DAW for meditation or going to sleep. Not all presets are suitable, unless you like nightmares. :lol:
Here’s the video:
https://youtu.be/5JpLUm8qbWc
Download for the zip with the usual stuff inside:
https://www.dropbox.com/s/59fd6s3qbd5zr ... 1.zip?dl=0
Have fun!
Re: Quilcom SIM-WINDHARP: The answer my friend is...
Postby billv » Sun Aug 22, 2021 9:32 am
Great stuff Spogg..some nice atmosphere's.. :)
Edit: Spogg, I'm getting a "files can't be previewed" error msg. Left click..right click..
same error and it happens with every file. So right now I'm feeling really Dumb :oops:
Please advise...what am I doing wrong?
Postby Spogg » Sun Aug 22, 2021 12:46 pm
billv wrote:Great stuff Spogg..some nice atmosphere's.. :)
Thanks Bill.
Can you give more info about your error message please? I’m puzzled why you would want to preview the files after you've downloaded and unzipped...
Postby billv » Sun Aug 22, 2021 1:23 pm
Spogg wrote:after you've downloaded and unzipped...
I haven't downloaded because I cant work out how....i don't see any download button
Clicking the files just brings error msg :?
Postby Spogg » Sun Aug 22, 2021 2:41 pm
On the sidebar top right, there are 3 dots at the bottom of the list. Click on that and you get the download option. Dropbox used to make it easier!
Postby billv » Sun Aug 22, 2021 9:44 pm
As you can see, there's no sidebar,no three dots,no list and no download option.
If I go 1 level inside the zip file,it's the same problem :roll: :? :?
Postby deraudrl » Mon Aug 23, 2021 12:38 am
What OS and browser is that? The screen-grab is too low-res to tell, but it looks like XP/Win7, with maybe some flavor of IE...might need Chrome to access the current DropBox site, assuming there's a version that will run on that.
Try this: https://help.dropbox.com/installs-integ ... t-homepage
deraudrl
Postby Spogg » Mon Aug 23, 2021 8:07 am
I’m using Windows 7 and Firefox browser. I tried Firefox in Private mode and I still see the sidebar with the 3 dots. Like Deraudrl said, I googled it and the main suggestion is a browser issue. I hope you can sort it Bill.
If not, you can get the same zip from http://www.flowstoners.com in the Quilcom section. It’s currently at the bottom of the list.
Good luck!
Postby billv » Mon Aug 23, 2021 8:43 am
Thanks Guys..it was a browser problem. I am using XP with Firefox v43 ,which is out of date,
as there now at v47.
I used Chrome and successfully downloaded. :)
Sorry if I stressed anyone..thanks again..cheers :D
Postby Halon » Fri Sep 17, 2021 9:18 pm
another great synth Rex. :) love what you are doing ;)
Halon
