Youlean FIR Filter DLL
Postby Youlean » Tue Dec 22, 2015 10:29 pm
Just DLL implementation of FIR filter.
Edit: Reuploaded...
Youlean FIR Filter DLL.zip
(196.79 KiB) Downloaded 1466 times
Youlean
Re: Youlean FIR Filter DLL
Postby martinvicanek » Tue Dec 22, 2015 10:58 pm
Youlean, is that an FFT convolution in your external DLL? In the schematic you mention "unlimited size". How much would that be, enough for an offline reverb? :?:
Postby Youlean » Tue Dec 22, 2015 11:03 pm
martinvicanek wrote:Youlean, is that an FFT convolution in your external DLL? In the schematic you mention "unlimited size". How much would that be, enough for an offline reverb? :?:
I recreated everything that is inside original MyCo module. Yes, it should work with any coefficients size as long your CPU and RAM allow it.
Youlean
Postby Youlean » Tue Dec 22, 2015 11:09 pm
Sometimes it will crash when you change coefficients size from big to small, but I think that this could be because of frame and green DLL update.
I think that stopping frame update before coefficient update would fix that...
Youlean
Return to DSP
