[Solved] Save/Load Preset Manager Error
Postby Wassaka » Thu Dec 31, 2015 7:11 pm
Hi!, I am Wassaka, First i want to say that my english is very very bad so, sorry :roll: .
The preset manager saves all of the data excepting the matrix routing... When I click to change the routing, I see the "Ticks or checks (✔) " Are in the correct position but, the matrix ignores this... Ok My english is too bad to explain, let me show an image xD.
Short: The matrix saves but don't loads...
As you can see, the tick is correct but then, look the matrix:
The matrix don't load it... The problem isn't the names of the presets, I change it...
I will share to you one of my presets:
https://www.dropbox.com/s/1hhlkncu36qmf71/LD%20Ages.ktr?dl=0
Please I need Help!! Thanks.
Wassaka
Re: Save/Load Preset Manager Error
Postby billv » Fri Jan 01, 2016 7:12 am
Yeh...that seems weird.
I dragged the Routing matrix and PM from toolbox and got no result..... :?
Seems to be the selectors.....don't know why....
I changed them with default selectors from toolbox and seems to work fine..
fix.fsm
(10.27 KiB) Downloaded 857 times
Postby Wassaka » Fri Jan 01, 2016 10:31 pm
billv wrote:Yeh...that seems weird.
fix.fsm
Thanks!!!!!! Very very helpful!!!! Happy new year :mrgreen:
Wassaka
