Possible adding naother waveform without effect presets?
i wana add 1 more waveform to my synth. is this possible without effect the presets?
- djbrynte
Re: Possible adding naother waveform without effect presets?
Changing or adding new preset parameters will mess up the presets and specially saved project. I for myself try to finalize everything before using or releasing it.
I don't know if there is a way to somehow get around this problem. Maybe someone here would know if its possible.
- Father
I've found by experience that any addition or change of components in a schematic will somehow "upset" the preset parameters that have been stored in the code for the schematic ("inside" the Preset Manager as I think of it).
I've found that most of the time, when I'm creating some presets at the begining, I think of a modification that will improve the experience.
The solution then is to save all your current presets in a "save all" set, make the modification to the schematic, then re-load all the existing presets. Then finally save-as the newly modified schematic to capture the new configuration and its updated presets.
Failure to follow a process like this can result in some very odd and (to me) unpredictable results when a change is made to the schematic.
I hope this was a clear explanation.
this explains it wont work
ok i got it.
- djbrynte
Spogg wrote:The solution then is to save all your current presets in a "save all" set, make the modification to the schematic, then re-load all the existing presets. Then finally save-as the newly modified schematic to capture the new configuration and its updated presets.
This actually can rescue your presets saved/loaded by flowstone preset system. But the DAW saves and loads in a different way, so i think there is no way to do something about that.
The solution could be in a way to access and edit standard FXP layout? i don't know.
- Father
