For those not in the no (Tips and Tricks)
Re: For those not in the no (Tips and Tricks)
Jan.6, 2016
I found this nifty little '20 log 10' module somewhere in my travels, and I put it aside to evaluate it.
I built this set of schematics and I think it will help in understanding the power of logarithms.
Here are 3 schematics, ranging from 1 to 10, 10 to 100, and 100 to 10,000, and the logarithm of each set of numbers.
Have fun twiddling the stepper dials, notice how the module does some pretty fancy calculations.
Open up the dials, enter your own ratios, experiment, learn !
Enjoy and help the kiddies (and ME) understand these things !
Roxy
Roxy
ROXY Log Transfer Function -5 - 1-6-2016.fsm- Have fun learning about logarithms !
- (57.02 KiB) Downloaded 1209 times
rocknrollkat - Posts: 213
Jan.9, 2016
For the beginners, here's some things to know about 'knobs'.
As supplied, they deliver a 'voltage' from 0 to 1.
These are NOT voltages, but numbers.
It took me a while to get used to that idea, you can't burn things out with too much 'voltage', etc.
You can program the output of these 'knobs' to deliver any range of numbers you like, including negative numbers, and numbers in a nonsymmetrical range.
I set up three 'knobs' (that word STILL 'kills' me), the first one is what you get out of the box, 0 to 1.
The second one I reprogrammed to go from -1 to 1, and the third is an asymmetrical output of from -3 to 12.
Open 'em up, see what I did, and now you know how to develop your own custom 'knobs' !!
Enjoy,
ROXY
Enjoy,
ROXY
'Knob' Basics.fsm- For the newcomers, some ideas about 'knobs' that can save you a lot of time.
- (56.75 KiB) Downloaded 1184 times
Jan. 9, 2016
Here's another super simple setup that demonstrates how 'inversion' works.
So simple a child can do it, but when you have to invert a number stream, you can spend hours trying to figure it out.
I did it for you, enjoy this little tip and save some time !
All the best,
Roxy
All the best,
Roxy
Number Inversion.fsm- (56.35 KiB) Downloaded 1209 times
Jan.10, 2016
As promised, here's a nice piece of test gear we use here to test levels throughout a schematic.
Since we export a 44.1 kHz 16bit format, this meter is set to read down to -96 dBs, the lower limit of 16 bits.
It will also read OVER the 16 bit limit of 0 dBs, so you can avoid head crashes or otherwise overtaxing your brickwall limiter, which you shouldn't need anyway if you're doing things right.
If there is any interest in this type of thing, I will show you how to calibrate your soundcard and do many other procedures that will lead to a cleaner sound.
Now to that dB meter.
Set it up to what you know to be a correct 0 dB signal, and trim the meter to read 0 dBs.
Now you're ready to see what those signals are doing throughout your signal chain.
Enjoy !!
Roxy
Enjoy !!
Roxy
ROXY Mini DVU3-TO DSP - 1-10-2016.fsm- Let's look into the secret life of those levels !
- (14.61 KiB) Downloaded 1145 times
Jan. 20, 2016
Here's a schematic that can save you time in locating that rogue signal, noise source, etc.
Similar to Spogg's Threshold Mute, above, this set of two LEDs shows you at a glance WHICH faders are not completely OFF.
It also introduces you to some simple 'operator' gates, 'equal', 'greater than', well you'll see.
Just make sure that the number that you enter into the 'float' window is the SAME number as the LOW value of your fader or 'knob' (there's that word again).
Put one on every channel fader, and 4 hours into that mixdown session at 2 in the morning you'll start to see where this addon makes sense.
'Oh yeah, track 15 is still 'open', oooops' !!
Dead simple schematic, but that's the point of this thread, enjoy !!
ROXY
ROXY
Fader OFF-ON LED indicator.fsm- How long has channel 15 been 'hot' ??
- (28.35 KiB) Downloaded 1114 times
Hey, nice idea!
Jan. 21, 2016
Thanks, Spogg !!
I try to keep it simple, the devil is in the details, as I'm sure you know !!
Best regards from NYC,
ROXY
Thanks, Spogg !!
ROXY
January 21, 2016
Hi gang,
Here's an oscillator that nobody needs until they NEED one, then all work stops while they scour the forums for one.
Sweep generators are super handy for checking out frequency responses of various filters and other systems, amps, modulators, etc.
So instead of waiting 'til you need one, download THIS one and if nothing else, play with it and annoy the cats !!
Is it lab grade ??
Nope.
Will you be glad you have it ??
Yup.
Enjoy !!
ROXY
Hi gang,
Is it lab grade ??
Nope.
Yup.
Enjoy !!
ROXY
ROXY Sweep Generator -1-21-2016..fsm- Sweep Generators, the forgotten orphan children of the test bench, but just might save the day.
Here's yours now ! - (200.23 KiB) Downloaded 1141 times
really nice.
Thanks Roxy
Thanks Roxy
RJHollins wrote:really nice.
Thanks Roxy
You're welcome, RJ, use it in good health !!
ROXY
