transpose rows into columns
Postby tester » Fri Jan 22, 2016 11:05 pm
1) How to display whole transposed (rows into colums) matrix?
1a) How to display (as int) amount of columns after transpose?
2) How to approach to this, if input contains rows with different element sizes?
transpose.fsm
(466 Bytes) Downloaded 840 times
Re: transpose rows into columns
Postby KG_is_back » Sat Jan 23, 2016 12:46 am
Unfortunately flowstone ruby doesn't support standard ruby library, which contains Matrix class. Here is the solution - modified version of what you have in your schematic. It works also with arrays, which have different lengths of lines, or even missing values.
def transpose(matrix)
   #find longest line( to determine number of raws)
   ln=matrix.max{|line1,line2| line1.size<=>line2.size}.size
   trn=Array.new(ln){|i|
   matrix.map{|line| line[i]}
   return trn
asd1 = @in1.map do |row|
row.split('^')
watch "old",asd1
asd2 = transpose(asd1)
watch "new",asd2
output 0, asd2[@in2]
output 1, asd2.map{|line| line.join("^")}
to find the length of the longest line (the number of columns) use:
KG_is_back
Postby tester » Sat Jan 23, 2016 10:30 am
Thanks KG!
