delay modulation
delay modulation
Hello gang,
Even though I have now been on the forum for sometime now, I am still wondering, is there a wrong and right way to modulate a delay line? If yes, could someone please post examples of both. I searched the entire forum, but could not find any good examples at all. Many thanks in advance.
Later then, BobF.....
- BobF
Re: delay modulation
The important issue is how you interpolate. Linear interpolation is the simplest option and may be "good enough for rock n roll", however you will lose trebble. Allpass interpolation is preferred for slow modulation, If you have fast modulation then you can use some higher order interpolation, like a 4 point Lagrange. It really depends on your application.
Thanks Martin,
Much appreciated feedback.
- BobF
Users browsing this forum: No registered users and 47 guests
