Synthmaker Greatest Hits
Re: Synthmaker Greatest Hits
Happy Birthday
Wonderful!!
Thank you tulamide.
Thank you tulamide.
Happy birthday Spogg!
Loopeytunes - Posts: 57
May the Force be ... oh wait ...
Live Long and Prosper
Hi Spogg, qoSlIj DatIvjaj
- BobF
Thanks guys for the birthday wishes, I was really rather moved by that.
I feel like I'm amongst good friends on this forum and this has confirmed that for sure.
2 Drum pads with MIDI learn
These pads look good and seem to work well. There are 2 versions here. One outputs full volume when you click on it. The other one creates a note velocity response according to the vertical position of the mouse on the pad when you click it.
Since it's a MIDI learn system for the note number for each pad you can just copy and paste as many pads as you need for your drum-pad machine.
Spogged: Nothing but I didn't test the knob's MIDI learn. The pad worked. Right click on the pad, select learn and hit a note on your pad or keyboard.
Author: Loopeytunes and the author has provided some credits in the schematic.
Drum Pad with mouse position to velocity.fsm- (227.53 KiB) Downloaded 1479 times
Drum Pad .fsm- (227.55 KiB) Downloaded 1407 times
Sorry, the board attachment quota has been reached.
I was about to do another upload and I got the message above.
Does anyone know if I have to start a new topic, is it a personal limit or is the board now full?
Not sure what that means Spogg, never had that before.
Also the Drum Pads by me
This is just to test if it is a personal limit.
dummy.fsm- (1.01 KiB) Downloaded 1412 times
