Using Assembler code outside Flowstone
Postby Perfect Human Interface » Wed Feb 03, 2016 9:35 am
Hi all. If one were to go about recreating a Flowstone plugin in another programming language, say C++, how feasible would it be to copy assembly language code right out of FS to reuse it?
Re: Using Assembler code outside Flowstone
Postby Youlean » Thu Feb 04, 2016 3:27 am
It will be very easy to do this, but there is chance that it woudnt work on x64...
Youlean
Postby Perfect Human Interface » Thu Feb 04, 2016 3:30 am
Youlean wrote:It will be very easy to do this, but there is chance that it woudnt work on x64...
Do you mean that the assembly code may potentially need to be modified for compatibility?
Postby tulamide » Thu Feb 04, 2016 4:25 am
Assembler is very close to machine language, which means you need different codes for each platform you're exporting to (32bit Windows, 64bit Windows, Mac, Android, etc.)
Postby Perfect Human Interface » Thu Feb 04, 2016 4:29 am
tulamide wrote:Assembler is very close to machine language, which means you need different codes for each platform you're exporting to (32bit Windows, 64bit Windows, Mac, Android, etc.)
I see. Are we talking generally just replacing a few bits or a significant rewrite, or impossible to say?
Postby tulamide » Thu Feb 04, 2016 4:52 am
This may be answered by Martin, Exo, Myco and the like.
What I can say is that it the opcodes vary, as well as memory addressing and bit-depth of value types.
Postby Nubeat7 » Thu Feb 04, 2016 8:36 pm
depending on how you are doing it in c++, i would work with crossplattform enviroment, like juce or WDL, additionally you will maybe use specialized libraries for dsp..
these are optimized frameworks and libraries, so normally you don't need any assembler, all in all it will be easier to rewrite the codes, better to write clean and optimized c++ code then coding around corners to fit in existing assembler code.. anyways when you wrote your plugins in assembler you will have the dsp codes for it too which is really easy to rewrite in c++
Postby Perfect Human Interface » Fri Feb 05, 2016 12:49 pm
Thanks for all the responses!
Postby TheOm » Fri Feb 05, 2016 12:59 pm
I would recommend to rewrite your assembler into intrinsics.
This should usually be a very straighforward conversion.
Intrinsics are compiler-specific though.
TheOm
Users browsing this forum: No registered users and 65 guests
