New project idea
New project idea
Gonna try to approximate this very cool EQ used by Decca in the Sofiensaal from Gotterdammerung on:
Anybody have a cool rotating text module I can use on the knobs?
Pretty exciting to think I can use this vintage Decca EQ concept on my own Classical recordings!
Re: New project idea
Here we are K:
Credit has to go to ChrisHooker for the original upload.
http://www.dsprobotics.com/support/viewtopic.php?f=2&t=17246&hilit=rotating&start=20
If you look on page 3 of the topic there are some related goodies from Trogg & Nubeat.
Have fun
Have fun
DaveyBoy - Posts: 131
No, not curved text, but text on a knob that rotates with the knob (see pic).
k brown wrote:No, not curved text, but text on a knob that rotates with the knob (see pic).
Text rotation is not part of GDI+ and therefore not available in Flowstone. You could painfully draw the text into a bitmap and rotate that one with the knob, but that would be way to much work for this small effect.
Instead build a graphic containg the text for rotation and rotate it in Knobman.
Does something like that helps?
rotate text with a knob 3.06.fsm- Made with v3.06
- (6.16 KiB) Downloaded 849 times
kortezzzz - Posts: 763
I'll give it a shot, thanks.
kortezzzz wrote:Does something like that helps?
That's a good example of the bitmap rotation I talked about. Rotation is more expensive CPU wise than just drawing a bitmap, but this shows very well, how it's done!
It was on my To do list but you beat me to it! It’s what I had in mind.
Well done that man!
tulamide wrote:That's a good example of the bitmap rotation I talked about. Rotation is more expensive CPU wise than just drawing a bitmap, but this shows very well, how it's done!
Thanks.
It's also a little heavy with triggers expenses. But as long as the plugin is simple and lightwieght, it shouldn't be a problem.
Spogg wrote:It was on my To do list but you beat me to it! It’s what I had in mind. Well done that man!
Unfair match because I've already needed something like that before, so it was lying in my toolbox..
I'll do two versions of the EQ, with and without the rotating text; will be interesting to see what the diff will be in CPU load.
