Prototype - Free running poly oscillators
Re: Prototype - Free running poly oscillators
Postby Father » Mon Jun 22, 2015 10:34 pm
Great work everyone, this is an essential tool. Still working on this?
I came across the advanced poly porta at the blog, and posted a bug here: viewtopic.php?f=2&t=3556
now i see its related to this post.
Hope you guys come up with a 100% working version soon.
Father
Postby Kirill_Neoris » Sun Feb 07, 2016 10:13 pm
Hello, guys 'n girls!
I've stucked into the fact that I can't make my LFO's running freely using this great thing.
It's really great because at least the oscillators now can run freely. But not LFO. Why? I'm not a coder :)
Currently I'm making the synth that is pretty much close to be completed (not mentioning few optimizations that need to be made). But not these LFO :D This make me a bit sick.
Yeah, I can nail it with external LFO's in my DAW.... But it's not cool and will not able to cover everything quickly. Every good patch will be linked with tons of different setting for LFO's in DAW. It's really slow...
Maybe I'm doing something wrong here? Can you check it?
Free LFO Synth_2.fsm
(847.7 KiB) Downloaded 1756 times
P.S. I'm not panicking... But actually these things (like "clocks" and free running oscs and lfos) are very important for any synth creating editor program. I was really surprised that it wasn't solved for few years in the core.
For me it's more important than having a possibility to export to VST3. FS Authors... If you're ignoring such things, I think you're stepping behind other competitors that make alike products.
Kirill_Neoris
Postby adamszabo » Sun Feb 07, 2016 10:55 pm
The problem is that the wireless links are not connected in the Last Value Store V1.0.3 module.
adamszabo
Postby Father » Sun Feb 07, 2016 11:07 pm
I didn't really study your schematic but look closely at the wireless connections inside free running tool. Connect them like the original example, and hopefully you can make it work.
Father
Postby Kirill_Neoris » Mon Feb 08, 2016 12:04 am
adamszabo wrote:The problem is that the wireless links are not connected in the Last Value Store V1.0.3 module.
Oh, yes! :) It was really it! :))
Thank you guys that you've pointed out this silly bug of me! ))
Naively I've thought that wireless links works globally. But these things has big limitations although these are handy in some cases.
Probably tommorow after work (it's night here) I'll finish my synth and make a .dll for people here.
Kirill_Neoris
Postby Father » Tue Aug 22, 2017 10:08 pm
Hey guys
I think the 'Last Value Store V1.0.3' module inside both 'free phase run' and 'poly porta' causes the plugin to crash somehow (unexpected times, sometimes memory access error, etc. Using 3.0.5 here).
Can anyone investigate and come up with a fix or alternative stable solution maybe?
Father
Prototype Free running poly oscillators
Postby NateRuky » Mon Sep 25, 2017 6:51 pm
Just a few months ago I was right where you are now. Good luck with your project. You'll find plenty of support here on these forums. Any thoughts on a theme yet?
NateRuky
Postby ErvSoft » Fri Jan 15, 2021 3:09 pm
ok, in the last scheme of Kirill_Neoris I corrected some connections, and the only problem I found is that when setting the voices limit to 1 in the Multy component, the LFO freezes when playing with the keys:
Krill Neoris Free LFO Synth_v3 FSv306.fsm
schedule of Krill Neoris_v3 (fsm v 3.0.6)
(1021.59 KiB) Downloaded 1070 times
when pressing one key by one, at times the LFO freezes, and if it is held down in that moment of freezing, and other keys are pressed, the LFO continues to function,
and the funny thing is that by increasing the number of voices in the Multy midi component
the LFO works without freezing,
now, I do not know about how to correct that problem,
but, I think it may be related to Flowstone interpreting the LFO as a voice that adds to the OSC making the OSC have priority over the LFO and because of this it makes the LFO not play when the number of voices is established in 1 ?
I will stay tuned to this thread.
ErvSoft
Users browsing this forum: No registered users and 133 guests
