Baq EQ example
Baq EQ example
Postby regressor18 » Fri Apr 01, 2022 7:15 pm
Attached is a Baq EQ I did that closely emulates my Dangerous EQ in my rack. I used Plugin Doctor to very closely match my shelves to the hardware.
I would love for the community to take a look at this fsm and assist in optimizing. Under the hood, its very basic. 1 LS and 1 HS, both are using Martin's ZDF. Martin, if you are reading this THANK YOU for all of your work with Flowstone. I will say the HS at higher frequencies is experiencing Nyquist warping.
Lastly I did use an older beta of the 64 bit version to build this.
Matt
BaxEQ example.fsm
BaxEQ
(165.37 KiB) Downloaded 568 times
regressor18
Re: Baq EQ example
Postby martinvicanek » Sun Apr 03, 2022 9:19 am
regressor18 wrote:I will say the HS at higher frequencies is experiencing Nyquist warping.
Confirmed.
You could use my newer set of matched filters from here:
viewtopic.php?f=2&t=89976#p225010
These are supposed to handle cutoffs even beyond Nyquist. The DSP part is optimized ASM.
Re: Baq EQ example
Postby regressor18 » Sun Apr 03, 2022 2:31 pm
Hey Martin,
Thank you for the reply!
When I use those filters, the filter crashes with a gain value of 0. Any idea what im doing wrong?
BaxEQ example HS issue.fsm
(164.11 KiB) Downloaded 549 times
regressor18
Re: Baq EQ example
Postby regressor18 » Sun Apr 03, 2022 3:03 pm
I think i resolved the issue. Can someone take a look.
BaxEQ example HS issue-Resolved.fsm
(164.14 KiB) Downloaded 551 times
regressor18
Re: Baq EQ example
Postby martinvicanek » Sun Apr 03, 2022 6:22 pm
regressor18 wrote:the filter crashes with a gain value of 0. Any idea what im doing wrong?
My bad, thank you for pointing this out. Fixed in version IVb in the original post.
regressor18 wrote:I think i resolved the issue.
Not for Q = 1 and above, unfortunately. Please use my fixed version IVb.
Re: Baq EQ example
Postby regressor18 » Sun Apr 03, 2022 11:17 pm
Thanks Martin!
regressor18
Re: Baq EQ example
Postby regressor18 » Mon Apr 04, 2022 2:15 am
Hey Martin,
The HS is very unstable. If you move the gain knob back and forth it crashes the filter. Any suggestions?
BaxEQ example HS issue-unstable.fsm
(164.21 KiB) Downloaded 558 times
regressor18
Re: Baq EQ example
Postby martinvicanek » Mon Apr 04, 2022 6:47 pm
No problems here with FS 3.0.8.1 or FS alpha. If you are using FS beta, that might be the problem.
Users browsing this forum: No registered users and 42 guests
