How "draw" method is executed from Stack in FlowStone/Ruby?
Re: How "draw" method is executed from Stack in FlowStone/Ru
Postby nix » Fri Mar 25, 2016 11:02 am
Here is the arp that rDSP built->
Example Synth.fsm
(199.32 KiB) Downloaded 1015 times
Also my sequencer again=>
DS_RC2015_308_0.fsm
(372.04 KiB) Downloaded 1002 times
I will try and help mate, hopefully this isn't a core problem.
You can correct drifting by quantizing to a mIdi note on
nix
Postby Nowhk » Sat Mar 26, 2016 9:29 am
Nubeat7 wrote:and what a surprise, null! just a zero line on both channels!
so 2 times recorded and the files are exactly identical, which proofs the stability of the ruby timing!
But did you change something in my schematic? If not, that proof nothing, since me (and nix) still got the same problem. If thats not a problem in Cubase doesnt mean it isnt a problem at all :shock:
Nowhk
Postby Nubeat7 » Sat Mar 26, 2016 1:46 pm
i didn't change anything on your code..
i also don't know what you did wrong, i tested it in fl studio too now and everything its fine
i did the same test as in cubase, i exported 2 times, inverted one file and its just a zero line after exorting the output again
here are the testfiles..
i'm sure you can test it on live or reaper too... just take care to do the test right!
fltest.zip
(575.22 KiB) Downloaded 977 times
Postby Nowhk » Sat Mar 26, 2016 1:58 pm
As I said its cyclic for "Session" (instance of FlowStone).
Load the schematic on channel 1->route mixer insert 1. Than load the same schematic (new instance of Flowstone) on channel 2->route mixer insert 2. On this one invert polarity, and press play. (as in my flp example; If you don't have FL 12 Ill make example in FL 11).
I can hear sound. Null test fails...
Ill try in Live 9 asap...
Nowhk
Postby Nubeat7 » Sat Mar 26, 2016 4:00 pm
also works!
2 instances of the testmodule one sends to port 1 the other to port 2 and 2 receiving synths (on port 1 and 2) with the same settings..
are you using asio driver for testing?
Postby Nowhk » Sat Mar 26, 2016 6:17 pm
Nubeat7 wrote:also works!
Yes, of course. The native ASIO Driver of my soundcard. Try this:
Internal MIDI Sync VST.zip
(1.85 MiB) Downloaded 976 times
it's the exported VST version of this schematic:
Internal MIDI Sync VST.fsm
(163.15 KiB) Downloaded 966 times
Load it twice in FL Channel rack 1 and 2, going on mixer insert 1 and 2 and on one of them reverse polarity. Than hit Play on the DAW. I can hear sound. Do you?
Maybe its a 3.0.7 bug? If so, can you take my schematic and export it as VST on your 3.0.9 and share? So I can check it.
Nowhk
Postby Nubeat7 » Sat Mar 26, 2016 11:22 pm
you are right, with the waveplayer included (also tried with osc's) i get randomly small noises, also when its pretty rare (1-2 times in half a minute), i could think that its because of audio priority !?
i don't have this issue using it only as midi plugin triggering an external synth, and also not after rendering...
Postby Tronic » Sat Mar 26, 2016 11:38 pm
input 99, nil, t+0.2 :cry:
You have to use the primitive Frame Sync
Tronic
Postby tulamide » Sun Mar 27, 2016 1:55 am
Tronic wrote:input 99, nil, t+0.2 :cry:
Not to say, I already told that, but:
http://www.dsprobotics.com/support/viewtopic.php?f=2&t=4215&start=20#p23683
Postby Nowhk » Mon Mar 28, 2016 11:18 am
Happy easter to everybody 8-)
Ive read about it, but that just send the buffer size when a buffer is processed by FlowStone. I dont see the point to use it here, where I need to trigger that Ruby event after n MS (or after x samples).
Are you suggesting to use counter/flag inside Ruby and trigger internal method once I reach the amount of samples that is equal to the starting note point?
Nowhk
Users browsing this forum: No registered users and 37 guests
