Things That Make You Go "Hmmm..."
Postby S1User » Thu Mar 31, 2016 4:22 pm
One of those random things that make you wonder why it is...
I wonder why Ruby uses a modified key character for comments? (#) It's obvious switching between multiple languages, Ruby, Lua, VB, the relative annoyance of having to use the CTL mod to get to it.
LUA: --
VB: '
Ruby: CTL+3 (#)
Was it maybe the case that when they created Ruby the # key was a standard exposed key or something?
S1User
Re: Things That Make You Go "Hmmm..."
Postby tulamide » Thu Mar 31, 2016 7:23 pm
Indeed, you made me go "hmmm..." ;)
Are you aware that there is a great number of keyboard layouts? You will never find that one 'comment instruction sign' valid for all of them. US has '#' at shift+'3', vietnamese on Alt Gr + '3', canadian french on the key left to '1', italian on Alt Gr + the key far right in the third row, german on that very same key but without Alt Gr, etc.
I would experience the same as you but in VB, because that '-sign is a combination on my keyboard.
Btw, you can also comment like so in Ruby:
=begin
I am a fantastic comment
(...write as many lines as you wish...)
=end
Postby martinvicanek » Thu Mar 31, 2016 11:04 pm
=begin
that's about the least intuitive multiline comment coding I know
=end
but wait, HTML is equally bad
I really like C style
Postby Perfect Human Interface » Fri Apr 01, 2016 12:30 am
martinvicanek wrote:
The worst ever!
Postby tulamide » Fri Apr 01, 2016 3:36 am
martinvicanek wrote:/*
[/code]
Not that I like it much, but at least it's been there for ages. Why don't just all agree on one kind of commenting like C. At least Javascript, PHP and Arduino (but maybe more) use the same syntax // and /* */
And older ones will certainly know where this comes from:
REM No multiline comment support
REM but we used to comment as little as possible xD
Postby RJHollins » Fri Apr 01, 2016 5:46 am
Commodore ?
Postby Spogg » Fri Apr 01, 2016 2:10 pm
RJHollins wrote:Commodore ?
Certainly Sinclair Basic!
Postby S1User » Fri Apr 01, 2016 4:03 pm
Yeah. I kinda hate code editors that don't have shortcuts for things like that, where you can't just select a block of code and hit CTL+Whatever to comment out a block 'o code.
S1User
