Flowstone will not run
While using flowstone had a power outage, now flowstone will not run, Windows says there is an error and shuts flowstone down, I reloaded flowstone and still same problem.
- ChrisMar
Re: Flowstone will not run
ChrisMar wrote:While using flowstone had a power outage, now flowstone will not run, Windows says there is an error and shuts flowstone down, I reloaded flowstone and still same problem.
My first stop would be to delete anything in the recovery folder;
C:\Users\Spogg\AppData\Roaming\FlowStone\Recovery
Let us know...
Spogg - Posts: 3358
Thanks Spogg, Recovery file is empty, i removed flowstone and reinstalled, Will not run
- ChrisMar
ChrisMar wrote:Thanks Spogg, Recovery file is empty, i removed flowstone and reinstalled, Will not run
Then I would make a temp backup somewhere for the AppData\Flowstone folder and delete the whole Flowstone folder, uninstall it then do a disk error check: Right-click on the drive, select properties, tools, and check for errors. Then re-install Flowstone. I suspect a disk corruption of some sort...
Spogg - Posts: 3358
Thank You Spogg, That did the trick
- ChrisMar
ChrisMar wrote:Thank You Spogg, That did the trick
Yay!!
Spogg - Posts: 3358
Users browsing this forum: No registered users and 63 guests
