Web Audio Stream Application does not work
Hello,
the example 'Web Audio Stream' application from the 'Example Schematics' sub-forum does not work, neither from within FlowStone nor as exported .exe.
It doesn't load the stream at all. When I paste the provided example URL into WinAmp it plays fine.
When I click on 'Play' for http://stream-ny.radioparadise.com:8002 it tries to make a connection to 127.0.0.1, port 49668. Of course no one's listening there...
Additionally it tries to access the DNS/RPC client. After that it's just idle doing nothing.
When I paste the path to a local (file based) .mp3 file this file gets played fine.
I'm using FlowStone Prof. V 1.0.12., Windows 7 64 bit.
Tom
Tom
- TomC
Re: Web Audio Stream Application does not work
Oh, and a dedicated bug-report forum would be a good idea
- TomC
It could be that you have a missing dll on your system?
The audio stream uses the VLC dlls which should auto install with the latest version of FlowStone!
It works on my system?
- DSP
Doesn't work for me either....
- Exo
This is a missing dll the same as for the video audio playback.
Download these dlls and put them into your Windows/System32 folder and it should work:
http://www.dsprobotics.com/Files/vlcdlls.zip
- DSP
Thanks
It seems that on windows7 64bit the dlls need to go in the Windows/SysWOW64 folder instead of the /System32 folder.
Exo
Exo
- Exo
I've put the libs into the Windows/SysWOW64 folder, but the only working link is exactly YOUR example. I've found 2 other ones which heavily stutter, everything else does not work at all.
Should a simple m3u playlist pointing to mp3 files work?
Tom
Tom
- TomC
hey any solution to this yet? i get the same reported buffering no matter what i try.
Scope DSP Plugins and more
http://www.oceanswift.net/
- faxinadu
