->Analog Saturation<-
Postby DigiTonix » Tue May 17, 2016 1:17 pm
My Projects associated with an experimental simulation of analog saturation, I'll refine it in the future, and to improve as much as possible,
waiting for your comments!
Analog Saturation.fsm
(350.18 KiB) Downloaded 1326 times
DigiTonix
Re: ->Analog Saturation<-
Postby Spogg » Tue May 17, 2016 4:53 pm
DigiTonix wrote:My Projects associated with an experimental simulation of analog saturation, I'll refine it in the future, and to improve as much as possible,
Looks are really good and I love the on/off button and the flickering logo!
I can make changes to the sound but I'm not sure what all the controls actually influence! Any chance could you give a brief explanation to a stupid old Vulcan please? Or maybe label the knobs or something?
Plus, I was confused by the on/off bypass switch. When it's lit the effect seems to be bypassed. Was this the intention?
Thanks for sharing this too :D
Postby DigiTonix » Wed May 18, 2016 12:21 pm
Hi spogg...
When did this circuit, a bit confused ... so made a lot of mistakes to be corrected :oops: ... My main goal at the moment to make 3 types shaper that would copy the current-voltage characteristics of the 12aX7 standart, and Penthode... :roll:
DigiTonix
Postby tulamide » Wed May 18, 2016 12:25 pm
Hi DigiTronix,
Labeling the UI would be a nice idea. I understand that you can overdrive the input signal and reduce gain after saturation. But I am not sure, what this saturation is supposed to do?
I could either make it distort at extreme settings, or raise loudness. But I couldn't detect a saturation on not extreme settings, just loudness. I'm not very experienced with saturation, but I would have expected a more useful curve like here:
https://youtu.be/251yMm3hOD0
I'm not sure if my comment helps you?
Postby DigiTonix » Wed May 18, 2016 12:47 pm
Hi ... I analising Softube saturation knob ,,, got here such evidence ... quite interesting, it will be necessary to work with the assembler that it would happen ... probably
SK Test.gif (50.68 KiB) Viewed 27226 times
DigiTonix
Postby RJHollins » Wed May 18, 2016 6:02 pm
Are you controlling the level of 'Harmonics' ??
Postby StereoSpace » Mon May 23, 2016 9:23 am
So it's a stripped-down "Green Satura"
GUI designer
StereoSpace
Postby Nubeat7 » Mon May 23, 2016 8:21 pm
StereoSpace wrote:So it's a stripped-down "Green Satura"
you are talking about tor's "green eugene", i knew i saw that somewhere..
