DigiTonix Audio Tool's
• Page 1 of 3 • 1, 2, 3
DigiTonix - Posts: 137
Re: DigiTonix Audio Tool's
You might get more response if your download wasnt from an all Russian site. I cannot test your schematic here, however I notived that you are using rather old modules from the early SM days. You could have the same effect for less cpu today.
Ok ... Martin, thanks for the advice ... it is necessary to place the scheme at DropBox, .. this circuit we have done for a long time sings the old components, soon I will alter optimizes and ... just a little times because I'm busy working UI quality, special for Flow.
I really like the look of this. You have a good eye and talent for graphic design and I'm envious!
What tool did you use for the bitmap background?
Can you explain what the 3D Position section does please? To my ears it makes the sound "hollow" somehow.
Also can I steal the Waveshaper inside the compressor please? Did you personally make this?
I exported as a VST and, even though there are several superceded prims inside, it worked fine in Reaper.
Many thanks for sharing this really nice tool
When you create the background, I used 2 tools, Photoshop and free PaintNET ... At first I did texture, buttons, screws ... and then everything should be customized in size and color ... and then I did the glass panel with transparency, which is the source I'll give you a personal message, they are very useful and they should not be neglected ...
3D Installation, you understood correctly, it makes a sound transparent, using opiratsii concurrent filtering (This technology can also be used to simulate the resonance properties of real materials ..., metals, wood, etc.)
And of course you can steal my shaper waves, I think it will be useful and easy to use! ...
Design done in Adobe Photoshop and Adobe After Effects, I can share the project, if necessary
GUI designer
StereoSpace - Posts: 78
StereoSpace wrote::| Very interesting, what makes my then one of the first test circuits? Even my sketched logo)) I do not care, but somehow it is unpleasant, that taken over someone else's.
So, to clarify, this your work then Stereospace, and not Digitonics?
Oho! why is it your job ??? StereoSpace you are already tired to put his logo on other people's work! and not just for you and my EQ MyCo stole!!!
- VT-Develope.gif (35.31 KiB) Viewed 31251 times
Spogg wrote:So, to clarify, this your work then Stereospace, and not Digitonics?
All I hear is "a beef". Wait a second, I prepare my popcorn
So ... dot the AND! ... We pokozalos this StereoSpase who is the daddy !!! who will make steeper operating time at that and Eggs !
, (pardon the expression
) ... I'm super designer, and I'm doing for you all and FlowStone !, and do not hide anything as a mouse! ... Am I wrong,,, ?? ? Spogg, Tulamide, and all ...
