Comparator
Comparator
Postby BobF » Thu Jun 09, 2016 7:57 pm
Hell gang,
I could really use some help from someone who knows code and could code me a simple stream comparator. What I need is this. Comparison of relative states of plus and minus inputs. If the in(+)is greater than in(-), the output is 1, if in(+) is less than in(-), the output is 0. Only two states 0 or 1. This does have to work with streams as I am comparing two waveforms and need a stream of 1's and 0's from the the two compared streams.
For those that know electronics, this is just a simple analog voltage comparator.
Well that's it. Hope someone can help. If so many thanks in advance.
Later then, BobF.....
BobF
Re: Comparator
Postby adamszabo » Thu Jun 09, 2016 8:11 pm
If I understood correctly you have two inputs? Then this should do it:
streamin in1;
streamin in2;
streamout out;
out = (in1 > in2) & 1;
If in1 is greater than in2 it outputs 1, otherwise 0
adamszabo
Re: Comparator
Postby tulamide » Thu Jun 09, 2016 8:17 pm
Sadly I can't help with the code. But as I understand it, the absolute value is to be compared:
+0.6|-0.7
abs(0.7) > abs(0.6)
sign of the greater is negative, so output is 0
+0.6|-0.4
abs(0.6) > abs(0.4)
sign of the greater is positive, so output is 1
the abs function is pretty cpu heavy I've heard, so I don't know how to realize it with DSP.
Re: Comparator
Postby BobF » Sun Jun 12, 2016 3:36 am
Thanks, adamszabo and tulamide,
Sorry this is late. Just been busy like we all are.
Comments, tips, hits, suggestions, and so on are always very much appreciated.
BobF
Users browsing this forum: No registered users and 35 guests
