Stream Inspector v2
Stream Inspector v2
Postby MyCo » Mon Nov 19, 2012 3:06 am
I've converted my "Stream Inspector" Debug tool to FS and on the way I just found a better solution. So now, here is Stream Inspector v2:
It counts the "events" inside a stream eg. if there is "not a number" or "infinite" which can cause serious problems. It can also detect denormals.
The new version, does the detection in pure x86 assembler, so even when there are denormals, they don't have a huge effect on the counter. It is also more accurate, so it basically can't miss one sample.
I've included a DC Lowpass, that tries to find the DC Offset. It does that directly in stream, and it can go down into denormals (it is supposed to be so)... so when there are denormals, there are CPU spikes.
Hope it's usefull.
streaminspector2.fsm
(10.73 KiB) Downloaded 1542 times
Re: Stream Inspector v2
Postby trogluddite » Mon Nov 19, 2012 9:52 am
Many thank, MyCo, that is such a useful tool to have! :D
Postby Tronic » Mon Nov 19, 2012 3:34 pm
Thx, started MyCo tool-box folder ;)
Tronic
Postby Walter Sommerfeld » Mon Nov 19, 2012 11:14 pm
Yup - perfect... :D
keep on doing!
Walter Sommerfeld
Postby philton » Fri Nov 23, 2012 2:20 am
thx a lot Myco! very usefull :)
philton
Postby MyCo » Wed Nov 28, 2012 1:44 am
updated
there were some minor glitches with the Reset and Run/Stop button
Postby digitalwhitebyte » Wed Nov 28, 2012 4:47 pm
Yes, it is needed.
digitalwhitebyte
