Slow Ruby Ramp Generator
Postby aronb » Tue Jul 05, 2016 10:04 pm
Is it possible to build a slow Ruby Ramp generator?
I have looked on the forum and tried to make one in Ruby but it crashes, pretty much on every try...
I need to make many random ramps that are slow, and was hoping I could do it in Ruby. I landed doing it in the DSP, but was wondering if slow waveforms can also be generated in Ruby as well ? ? ? And by slow I mean about 10 samples per second or so...
I forgot to save before I ran it - it crashed, but I took a screenshot :oops:
Failed Ruby Ramp...
Thanks for any help or suggestions,
Aron
aronb
Re: Slow Ruby Ramp Generator
Postby KG_is_back » Tue Jul 05, 2016 10:55 pm
yes, this can be done. However, I'm not sure what you're trying to achieve exactly, so here are my few attempts:
1. From the image I see it seems you what to generate a wavetable for a ramp.
#inputs should be named "length" (float) and "tick" (trigger)
def event(i,v,t)
if i=="tick"
output 0, (0...@length).map{|i|
i.to_f/@length
2. If you want to generate a slowly changing green float output.
#input should be named "on" (boolean) and "period" (float)
def event(i,v,t)
if @on
@dt=t - (@dt||t)
@ramp=(@ramp||0.0+@dt/@period)%1.0
output 0,@ramp
input 99,nil,time+0.1 #change this 0.1 to whatever tick speed you need.
else
@ramp=0.0
@dt=nil
this will generate ramp that goes from 0 to 1 in predefined period time.
KG_is_back
Postby aronb » Wed Jul 06, 2016 4:19 am
OK...
I entered the Ruby code and while it produces an output it is not a ramp. I am still working thru this... a few of the code lines do not make sense to me at all, but I AM NOT a Ruby coder, but I am learning.
The input 99 is a callback to the input for ???
Here is my code...
Ruby_Ramp_01.fsm
Ruby Ramp
(65.82 KiB) Downloaded 944 times
does this look correct? It just seems complex for something like an up counter, but again I am not a Ruby coder :shock:
And to answer a previous question, I need a float output NOT an array... I can get the array version working, but not the "Streaming Green" version.
Thanks again,
Aron
aronb
