2SYNts- regular guitar to poly synth
Re: 2SYN-hex MIDI guitar!+synth
Postby nix » Sun Aug 14, 2016 4:23 am
Heya tribe,
I have written a proprietary synth in this format now,
called 2SYNth, here is the UI->
2SYNth screen mid_0.png (107.05 KiB) Viewed 38826 times
It's real simple in architecture.
I will add a mono mode and tuned fm in the next couple of weeks.
Also, I found the ver1.7 of the MIDI one would play a tone out too much.
I have changed it again a little. Smoothing the Chebyshev was too slow.
Version 1.7.1 is in the download.
If you'd like to try it the d/l link in the first post has been updated.
I will make demos for both of these releases hopefully today.
Cheers and imbibe the sweet melodies
nix
Postby nix » Sat Aug 20, 2016 9:07 am
Heya,
I have updated again.
Here are audio demos--
2SYNmidi:
https://soundcloud.com/nix808/2synpiano
2SYNth synthesizer:
https://soundcloud.com/nix808/2synth
I have been working on tracking more
nix
Postby BobF » Sat Aug 20, 2016 4:11 pm
Hi nix,
This was working great on my pc with Flowstone (3.08) under Fl Studio, till you put up 1.7.1. What changed? I would really like to keep keep following this. I may even have something to add.
Thanks, BobF.....
BobF
Postby nix » Sun Aug 21, 2016 6:38 am
Sorry Bob, I'm building it in FS 3.9.2,
and when I tried to save as 3.8, it still errors in 3.8.
I can try to get you a discount on 3.9.2?
That's real nice to hear it was working OK.
I have had no feedback from anyone who has tried it.
I have updated again, d/l in first post.
Also here is the synth, with a clean patch, ie. no hard sync->
https://soundcloud.com/nix808/2synth-clean
nix
Postby nix » Sun Aug 21, 2016 8:39 pm
So, after hearing from BobF-
I wanted to get this to open in 3.0.8.1.
I found it's the preset manager that was causing 'attempt to access file past it's end'.
Also string array handling is a little different.
-- so it opens fine now, and I just popped the manager back in.
edit- the current version is now built in 3.0.8.1 again, so u can get it in the first post(11/9/16)
If you need the graphics, they are in the zip file from Sendspace.
Hope it's interesting!-
Nick
(edit- I just tested if they open in the new FL12.3 with the latest FLFS, and they do fine)
nix
Postby BobF » Mon Aug 22, 2016 8:51 pm
Hi nix,
Thanks, I will take a look as soon as possible.
Later then, BobF.....
BobF
Postby nix » Mon Aug 29, 2016 11:40 am
Heya again,
I have updated with better tracking.
Get it in the first post.
Here is Alchemy VSTi with slide on:-
https://soundcloud.com/nix808/2syn-alchemy-slide
The 3081 files are a little broken, but they do load.
I will fix and update them soon.
nix
Postby BobF » Wed Aug 31, 2016 2:29 pm
Hi nix,
Did you ever get my PM, you never responded?
Take care, BobF.....
BobF
Postby nix » Wed Aug 31, 2016 2:48 pm
I got it,
I didn't realize the significance of your idea, so sorry-
and it slipped my mind to give you a hoy.
Thanks for the idea!
I will test it and get back to you.
Cheers!
I had a new thought too--
so harmonics are weak signals amplitude wise,
so I can use a power at the start of the detector.
The problem is that the high pitches are low in amplitude too.
It works pretty good, but like I say it attenuates the top frets as well as harmonics
...but your move is probably just killer!
nix
Postby nix » Fri Sep 02, 2016 8:03 pm
Here is analog synth:-
https://soundcloud.com/nix808/2syn-cheetah
Cheetah MS6 6-voice DCO
nix
