Let´s twist again
Let´s twist again
Postby philton » Fri Nov 23, 2012 3:23 am
just want to share theese "twist" modules i made some time ago .
maybe usefull for somebody. in fact just pre-made modules with 2 inputs and 2 outputs (A+B) and a boolean input.
if boolean input is true, the outputs will be twisted, means input A will be routed to output B and input B will be routed to output A.
Untitled 1.jpg (64.25 KiB) Viewed 10823 times
let´s twist again.fsm.fsm
let´s twist again by philton
(3.92 KiB) Downloaded 1630 times
philton
