Rounding and Float to Integer Errors (Solved)
Postby boris » Mon Nov 15, 2010 9:17 pm
There appears to be a rounding error were a conversion from a float calculation that results is a whole number is then connected to an integer data element. The result of the float multiply is display as a whole number - which I believe is rounded up - but results in a different integer value.
Attached is the schematic that seems to not make sense other than it being a bug.
I think we need a rounding primitive to be able to control results.
IntegerBug.fsm
Simple schematic
(258 Bytes) Downloaded 1533 times
boris
Re: Rounding and Float to Integer Errors
Postby Exo » Mon Nov 15, 2010 11:00 pm
Hey and welcome boris :)
This is not a bug. The float is rounded up for display purposes only, the underlying float is unchanged.
If you go into options under "Advanced" there is an option to turn "display floats as 32bit binary representations" on.
Switch that option on for the true value.
Cheers ;)
Exo
Exo
Postby boris » Mon Nov 15, 2010 11:10 pm
Ok Thanks
boris
Users browsing this forum: Google [Bot] and 9 guests
