*.hom (modules ) deleted
Postby payaDSP » Sat Oct 22, 2016 9:17 am
Hello to all;
is there way to use modules in toolkit (*.hom) erased by mistake.
mine are in "C:\Users\ap\AppData\Roaming\FlowStone\Modules\Deleted Modules"
OR
is there a way to convert HOM file in FSM usable again ?
Thanks
payaDSP
Re: *.hom (modules ) deleted
Postby Spogg » Sat Oct 22, 2016 10:54 am
AFAIK there’s no easy way to re-import a deleted *.hom module.
But this worked:
I tested this with a new temp module in my tool box then deleted it from my toolbox.
I closed FS
In explorer I moved the deleted hom module back into the /Modules/User folder.
Then I decided which toolbox tag I wanted it to appear in. Look in the Tags folder for the available tags.
I chose the .tag I wanted, and then opened it on a hex editor (Hex Nero editor), not Notepad -it just displays garbage.
I copied the last complete path, which you can see in the alphanumeric display in Hex Nero, along with the preceding semi-colon, and pasted it onto the end of the file. Then I changed the hom name to the one I wanted to re-install.
Then I saved the .tag file, opened FS and the module appeared back in my toolbox under the tag name I had chosen.
If anyone knows a better way to import *.hom files into the toolbox maybe they could let us know.
There may be a way to edit the registry but I don’t go there unless it’s the last possibility.
My conclusion is that in order to get a hom file into the toolbox it needs to be addressed in at least one tag file. Maybe some kind and super clever wizard could make a tag file editor in Ruby. The file structure looks to be quite simple.
Postby payaDSP » Sat Oct 22, 2016 2:05 pm
thank for your reply
i have tried about same thing
what i have understand:
*.tag structure is: "8A0002" begins always the same
for each HOM:
-then a char which seems to be from A to Z (i dont know the meaning or the order)
-then the complete path of the .HOM file
-then "02"
file finishes by "00"
To use a *.TAG you must include it in the "C:\Users\ap\AppData\Roaming\FlowStone\Tags\tagbar.txt" wich is plain text, one file per row.
:!: BUT It is not so simple some changes lead to complete toolkit cleaning and or FS bombing...
So make copy before trying some changes
in recording:
HOM files content schematic + picture (like icon) structure is mysterious (no way to transform HOM into FSM)
conceptor/developer/administrator/genius should be great to write some app to manage modules inside toolkit :)
payaDSP
Postby payaDSP » Sat Oct 22, 2016 2:44 pm
another way to get back your favorite module you have just deleted ( lost.hom)....
quit FS
open FS
create a new toolbox let's say "Come_back"
create a new module let's say "dummy" (should be C:\Users\ap\AppData\Roaming\FlowStone\Modules\User\dummy.hom)
close FS
search your deleted module lost.hom (in C:\Users\ap\AppData\Roaming\FlowStone\Modules\Deleted Modules\)
rename lost.hom in dummy.hom
then copy it back in C:\Users\ap\AppData\Roaming\FlowStone\Modules\User (you must overwrite the old one)
reopen FS
go to come_back toolbox
lost module is back :P
you can put it back in the place you want...
If this could help ...
payaDSP
Postby Spogg » Sat Oct 22, 2016 3:42 pm
Hey great idea payaDSP!
:D
This way you don't have to edit inside the .tag file
Brilliant!!
Postby payaDSP » Sat Oct 22, 2016 4:14 pm
many thanks
paya
payaDSP
