Up & Down Arrow Selectors with preset manager
Hello
Is there a way to use this up/down arrow selector with preset storing?
This selector doesn't work with preset manager.
Best regards.....
Best regards.....
Arrow.fsm- (9.42 KiB) Downloaded 1131 times
remarkable - Posts: 26
Re: Up & Down Arrow Selectors with preset manager
Like that?
Arrow_2.fsm- (7.17 KiB) Downloaded 1097 times
- adamszabo
Thank you Adam. How is your Viper Synth project going? I'm looking forward to use it!
In this issue, your approach is a preset manager that controlled with arrows.
But I actually like to only change preset manager. When presets are changed, the output index value will be remembered. How is it possible?
Its going well thank you
I am still not 100% sure what you would like. Here is another go. You can select a preset and the index will be sent to the +- buttons
Arrow_3.fsm- (7.18 KiB) Downloaded 1080 times
- adamszabo
Thank you so much Adam, that's what I exactly want
