The classic Synthmaker knob image,
I'm developing this GUI in VB.NET. And I thought itt'd be cool to have Ye Olde Synthmaker Knob converted to a bitmap strip. My question was,"with your permission", can I get the image used in the control from somewhere around Synthmaker? And where is it?
mHz - Posts: 19
Re: The classic Synthmaker knob image,
Not exactly sure what you want but I use this...
Knob bitmaps saving.fsm- (164.54 KiB) Downloaded 958 times
These things never worked in Synthmaker 2
I mean the shiny silver knob, it's just a single image I think it will look great with the baseline style.
Also I think it would be a good little throwback if it did make it into a release version.
It's this image.
It's this image.
mHz - Posts: 19
So, if you can capture a screenshot then edit it to what you want then use Knobman to create an animation strip...?
http://www.g200kg.com/jp/software/knobman.html
It has an alpha layer tho, but I can always fix something.
mHz - Posts: 19
Is that actual transparency though or is just burnt into the bmp?
It's a real alpha layer, I was looking at this link the other day.
http://gimpchat.com/viewtopic.php?f=23&t=4097
Think it's worth the time.
mHz - Posts: 19
Attached
- SM_Knob.png (3.64 KiB) Viewed 25607 times
Hey, Thanks! This is going to look so cool
mHz - Posts: 19
