The classic Synthmaker knob image,
Postby mHz » Wed Feb 22, 2017 3:07 pm
I'm developing this GUI in VB.NET. And I thought itt'd be cool to have Ye Olde Synthmaker Knob converted to a bitmap strip. My question was,"with your permission", can I get the image used in the control from somewhere around Synthmaker? And where is it?
mHz
Re: The classic Synthmaker knob image,
Postby Spogg » Wed Feb 22, 2017 3:21 pm
Not exactly sure what you want but I use this...
Knob bitmaps saving.fsm
(164.54 KiB) Downloaded 959 times
Postby mHz » Wed Feb 22, 2017 3:35 pm
These things never worked in Synthmaker 2 :),
I mean the shiny silver knob, it's just a single image I think it will look great with the baseline style.
Also I think it would be a good little throwback if it did make it into a release version.
It's this image.
mHz
Postby Spogg » Wed Feb 22, 2017 5:18 pm
So, if you can capture a screenshot then edit it to what you want then use Knobman to create an animation strip...?
http://www.g200kg.com/jp/software/knobman.html
Postby mHz » Wed Feb 22, 2017 6:07 pm
It has an alpha layer tho, but I can always fix something.
mHz
Postby Spogg » Wed Feb 22, 2017 6:35 pm
Is that actual transparency though or is just burnt into the bmp?
Postby mHz » Wed Feb 22, 2017 7:48 pm
It's a real alpha layer, I was looking at this link the other day.
http://gimpchat.com/viewtopic.php?f=23&t=4097
Think it's worth the time.
mHz
Postby martinvicanek » Wed Feb 22, 2017 10:47 pm
Attached
Postby mHz » Thu Feb 23, 2017 1:39 pm
Hey, Thanks! This is going to look so cool 8-)
Knob - Synthmaker.zip
(14.1 KiB) Downloaded 960 times
mHz
