Synthmaker bundle
Re: Synthmaker bundle
Postby k brown » Fri Feb 24, 2017 7:43 pm
I'll make a smaller version, but the text will probably be pretty hard to read. Are you on an HD display or SD?
Try this:
Rolend System 101M_Exp_small.dll.zip
(1.98 MiB) Downloaded 1138 times
Postby DrewDale » Fri Feb 24, 2017 9:25 pm
Just a standard HP Laptop display. Thanks for the smaller version, can read the text ok. Most appreciated :D
DrewDale
Postby k brown » Sat Feb 25, 2017 1:20 am
Good to hear - just polishing up now my take on the Moog System 35A; quite a wide thing, I'll be sure to include a small GUI version.
Postby k brown » Sat Feb 25, 2017 5:54 am
Got'er done. GUIs in three different sizes.
Synthegrated 35B:
Synthegrated 35B copy.jpg (105.33 KiB) Viewed 40595 times
Called 35B because it's a very slightly incomplete emulation of the System 35A, which was the System 35 without the Fixed Filter Bank.
Five oscillator beast!
Postby DrewDale » Sat Feb 25, 2017 7:28 pm
Nice work on the 35b, the smaller gui is just perfect. Sorry to ask, but any chance of making Block-1 smaller too, it looks like a great synth, but again very large for most monitors.
DrewDale
Postby k brown » Sun Feb 26, 2017 8:03 am
DrewDale wrote:Nice work on the 35b, the smaller gui is just perfect. Sorry to ask, but any chance of making Block-1 smaller too, it looks like a great synth, but again very large for most monitors.
Smaller GUIs now available for Block-8_horiz, Block-8_cables_horiz and both Block-1s.
Postby DrewDale » Sun Feb 26, 2017 9:03 pm
Many thanks on the GUI resize.
I have discovered an issue with the Insoniq Ezq-1. Each time I try open the synth in FL Studio, I get a browser window opening up in my documents and wanting a txt file called "filename" It is only after I click "Cancel" (on the popped up browser window) a few times that the synth actually opens. Very frustrating. I Hope I have explained it ok.
This doesn't happen with the FM version of the same synth.
Also MX-JR has audio clicking when first playing some notes, then leaving it a few seconds and playing more notes, the same audio clicking occurs. (not sure if the word Clicking is correct, but can't describe in words very well)
DrewDale
Postby k brown » Mon Feb 27, 2017 4:53 am
DrewDale wrote:Many thanks on the GUI resize.
EZQ-1 uses wavetable oscillators and has the option to load your own; those windows that pop up are related to that load function - at start up just click on them to make them go away. The synth has three oscillators, so a window opens up for each one. If you click on the little 'load' labels you see in each osc that same window pops up and you use it to load any wavetables you have saved as .txt. EZQ-FM doesn't use wavetable oscillators.
I couldn't detect anything amiss with Mx-Jr - are you sure you're the latest version; has the visible Preset Manager at the bottom and grey wave cross-fade knobs in the oscillators? Earlier versions had buggy delays in the EGs.
Postby DrewDale » Mon Feb 27, 2017 10:20 am
Thanks for the explanation regarding Ezq. As for the mxjr I downloaded the latest version before I posted on here.
DrewDale
Postby k brown » Mon Feb 27, 2017 11:19 am
DrewDale wrote:Thanks for the explanation regarding Ezq. As for the mxjr I downloaded the latest version before I posted on here.
Hmmm - then I'm really mystified; can you record some audio?
