what's new in Snowflake...
Re: what's new in Snowflake...
Postby support » Mon Dec 10, 2012 2:50 pm
Had another look at the tags issue. There is an issue in the install - it's overwriting the tag files. This would affect you if you've changed the tag bar or you've reassigned tags for primitives. Module tags should not be affected.
Sorry about this. We'll correct the install so it only writes if the tag files don't exist.
support
Postby Walter Sommerfeld » Mon Dec 10, 2012 2:59 pm
only Tagbar.TXT in AppData\Flowstone\Tags was overwritten with default i think:
External
Element
Maths
String
Flow
DSP
Audio
Imagery
GUI
System
Debug
Inside this folder are the user tags with their names..
I just edited the Tagbar.TXT and added my user tags like Luddite(w/o .tag) again...
Walter Sommerfeld
Postby support » Tue Dec 11, 2012 11:03 am
Thanks Walter. That's been corrected now - the install was overwriting the file. New installs were uploaded yesterday.
support
