Up & Down Arrow Selectors with preset manager
Postby remarkable » Mon Feb 06, 2017 6:01 pm
Hello
Is there a way to use this up/down arrow selector with preset storing?
This selector doesn't work with preset manager.
Best regards.....
Arrow.fsm
(9.42 KiB) Downloaded 1131 times
remarkable
Re: Up & Down Arrow Selectors with preset manager
Postby adamszabo » Mon Feb 06, 2017 6:08 pm
Like that?
Arrow_2.fsm
(7.17 KiB) Downloaded 1097 times
adamszabo
Postby remarkable » Mon Feb 06, 2017 7:38 pm
Thank you Adam. How is your Viper Synth project going? I'm looking forward to use it!
In this issue, your approach is a preset manager that controlled with arrows.
But I actually like to only change preset manager. When presets are changed, the output index value will be remembered. How is it possible?
remarkable
Postby adamszabo » Mon Feb 06, 2017 8:21 pm
Its going well thank you ;)
I am still not 100% sure what you would like. Here is another go. You can select a preset and the index will be sent to the +- buttons
Arrow_3.fsm
(7.18 KiB) Downloaded 1080 times
adamszabo
Postby remarkable » Tue Feb 07, 2017 6:33 pm
Thank you so much Adam, that's what I exactly want ;) :)
remarkable
Postby rdgaudio » Wed Mar 22, 2017 9:22 am
Adamszabo is 'Genius'. :D
JC Conkato
rdgaudio
