Reaper 5.4 problem about appearing in plugin list
Postby remarkable » Fri Mar 31, 2017 11:26 am
Hello
I had an issue with Reaper. I had to do a little bit of work to get the VST to appear in the Reaper V 5.40 plugin list, but after I cleared the cache and re-scanned it came up.
Is that about being my vst a 32bit plugin?
Best regards.
remarkable
Re: Reaper 5.4 problem about appearing in plugin list
Postby tulamide » Fri Mar 31, 2017 11:48 am
No. Reaper has a mechanism where each plugin during the checking is actually run and those who don't respond as expected are marked bad and don't make it into the list.
Reasons for not responding correctly are vast - but bit depth is not one of them.
Postby remarkable » Fri Mar 31, 2017 5:42 pm
tulamide wrote:No. Reaper has a mechanism where each plugin during the checking is actually run and those who don't respond as expected are marked bad and don't make it into the list.
So, what are the possible causes? I know there are too many possibilities but do you know some of them?
remarkable
Postby RJHollins » Fri Mar 31, 2017 6:05 pm
I know its happened ... just copy the .DLL file back into the VST folder [overwrite]. Then launch REAPER ... usually finds it [NEW].
Postby remarkable » Sun Apr 02, 2017 8:12 pm
RJHollins wrote:I know its happened ... just copy the .DLL file back into the VST folder [overwrite]. Then launch REAPER ... usually finds it [NEW].
Yes mate, this happens because DSPR can't handle customer care. They are really useless because of the 32 bit support only. They don't even care about it.
Damn I rellly regret buying this toy!
remarkable
Postby martinvicanek » Sun Apr 02, 2017 8:47 pm
Not everything is DSPR's fault though. I have been working with 32 bit plugins and Reaper without problems. Apparently Cubase is less considerate with backward compatiility.
Postby remarkable » Sun Apr 02, 2017 9:40 pm
martinvicanek wrote:Not everything is DSPR's fault though. I have been working with 32 bit plugins and Reaper without problems. Apparently Cubase is less considerate with backward compatiility.
Yes you are right my friend. But the problem is, FS doesn't need to be backward. It just can be an updated technology. That's what I mean about customer support :I
remarkable
Postby RJHollins » Mon Apr 03, 2017 12:39 am
I know some software co are finding issues with CUBASE [the guys that dev'd the VST format].
I'm also a REAPER user. And although I too wish FS go 64-bit ... all FS plugin builds that I've done are working in Reaper-64.
If there was an error ... it was most always my bad.
Can't add much more to this ... other than relaying my experiences.
Postby Nubeat7 » Mon Apr 03, 2017 9:55 am
i just can say he same as RJ Hollins, in my test phases of my plugins i always found some bugs to fix so that they worked in the daws without any troubles...
