Ruby Exercise
Ruby Exercise
So.... I needed a Hash where note numbers are the keys and note names are the values, so instead of typing it all out I thought it would be a good exercise to try and auto-generate it.
So whilst what I've come up with does actually work, I can't help thinking that there must be a more elegant, Ruby way of doing this.
Would any of the Ruby experts on here care to take a look and show me how it should be done?
Thanks in advance
Dave
# 1 - Generate note names, we need to start with C so doing it in 2 steps:
a = ((Array("C".."G") + Array("A".."B")).zip Array("C#".."G#") + Array("A#".."B#")).flatten
# 2 - Remove the B# and E#:
a.delete_if{|e|e == "B#"||e =="E#"} # gives: ["C", "C#", "D", "D#", "E", "F", "F#", "G", "G#", "A", "A#", "B"]
# 3 - Repeat a 11 times:
b = Array.new(11,a).flatten
# 4 - Generate 0 to 10 (the octave nos) 12 times and sort:
c =((Array (0..10)) * 12).sort # Gives: [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 1,... 10, 10]
# 5 - Zip b and c together and remove the last 4 elements:
d = b.zip(c).take(128) # Gives: [["C", 0], ["C#", 0], ["D", 0], ["D#", 0], ["E", 0]..... ["F#", 10], ["G", 10]]
# 6 - Join the note names and octave nos together:
e = d.map{|e|e[0] + e[1].to_s} # Gives: ["C0", "C#0", "D0", "D#0",...... "F#10", "G10"]
# 7 - Generate the Hash
notes = Hash[e.map.with_index{ |x, i| [i, x ] }] # Gives: {0=>"C0", 1=>"C#0",..... 126=>"F#10", 127=>"G10"}
watch notes
Thanks in advance
Dave
DaveyBoy - Posts: 131
Re: Ruby Exercise
Well, I don't see much sense in not using a string of key names, so this would be my turn.
You can then directly call a hash via h[desired_key], but be aware that the key.value pairs are only generated when they are requested for the first time ( for example, h[2] calls the proc if not yet defined )
a = "C C# D D# E F F# G G# A A# B".split
h = Hash.new
h.default_proc = proc do |hash, key|
hash[key] = a[key % 12] + (key / 12).to_s
Re: Ruby Exercise
Wow... that's brilliant, and so short too.
I knew there had to be better ways of doing this but I never expected it to be so concise!
I've never programmed before and only been doing Flowstone for about a year or so (guess it shows
), so I think it may have been another year or two before I'd have done it like this.
Got some studying to do now to see how it works.
Thanks Tulamide
Thanks Tulamide
