deleted primitives, modules not removed?
Postby infuzion » Mon Nov 19, 2012 4:56 pm
Can someone please verify if this bug is also in FlowStone 3.0.0?
http://synthmaker.co.uk/forum/viewtopic ... 043#p90043
infuzion
Re: deleted primitives, modules not removed?
Postby support » Mon Nov 19, 2012 6:34 pm
Yes it is, but it's not quite as you think it is. The bug is in the statistics dialog - it's counting components that it shouldn't, namely those created behind the scenes for serving up the properties. These get created and deleted on the fly. The stats shouldn't include these.
So don't worry, there are no components being left behind after deletion.
We will correct the bug in the stats that incorrectly counts property item components in the first update.
support
Postby infuzion » Tue Nov 20, 2012 3:51 am
Cool, cheers!
infuzion
Postby infuzion » Mon Dec 24, 2012 1:34 pm
support wrote:Yes it is, but it's not quite as you think it is. The bug is in the statistics dialog - it's counting components that it shouldn't, namely those created behind the scenes for serving up the properties. These get created and deleted on the fly. The stats shouldn't include these.
Has this been fixed in 3.0.1 please? I do not see it listed in the release notes: http://www.dsprobotics.com/versions.html
infuzion
Postby MyCo » Mon Dec 24, 2012 7:18 pm
Yes, it's under fixes:
Fixed a bug with the statistics calculating incorrectly when property panels are being used
Postby infuzion » Mon Dec 24, 2012 9:34 pm
MyCo wrote:Yes, it's under fixes:
There it is! Cheers MyCo.
infuzion
