Redraw + sfz problem
Postby Freddymusic » Wed Dec 26, 2012 11:37 pm
Hi!
I tested some SM2 file in the FS free. It's new for me. I have a project with too much graphic. These are work only one thick100 with a lot of wireless output. So it's work on SM2, but in the flowstone the redraw isn't work. The graphic is change, if i click on the editor aera. Is problem have in only the free version or it will be in the full FS? I replaced the ticker, but nothing to happened. Now i think isn't a bug, FS just can't operate too much thicker data.
Next: if i wan't to use the save txt and load function with sfz parser, FS is freezing. The sfz Parser is perfectly work in SM, but in the flowstone it's not load the sounds anytime.
freddymusic.hu
Freddymusic
Re: Redraw + sfz problem
Postby Freddymusic » Thu Dec 27, 2012 4:37 am
Ok, I used the 3.0.0. Now i installed the 3.0.1 and now i have not redraw problem. Now i have not sfz freezing, but the sfz parser isn't work yet.
freddymusic.hu
Freddymusic
Postby digitalwhitebyte » Thu Dec 27, 2012 9:53 am
you can attach a small sound bank used by you to do the test?
digitalwhitebyte
Postby Freddymusic » Fri Dec 28, 2012 3:09 am
Your question give me an answer.
So i have some info in the sfz file behind the "//" I removed it with a txt editor and now sfz is good. It was a little problem but the synthmaker was good with this info in the sfz file. So thank you your question! :D
freddymusic.hu
Freddymusic
Postby digitalwhitebyte » Fri Dec 28, 2012 4:30 am
I'm happy to be helpful :)
digitalwhitebyte
Return to DSP
Users browsing this forum: Majestic-12 [Bot] and 191 guests
