Hiring someone to help me with Flowstone Synth
Yo im trying to make the coolest best synth possible with flowstone. i already have a good rough demo and a plan. I just have a few problems and i would love to speak with an experienced Flowstone developer.
This is my channel > https://www.youtube.com/channel/UCKcYlT ... ghWm0V_GNg im trying to take over the art and music industry
ZAYNE
zayne - Posts: 24
Re: Hiring someone to help me with Flowstone Synth
My major problem that stumped me right now is AHDSR Retriggering with my Step LFO. My AHDSR is attached to a pitch in the matrix. My step lfo is attached to the OSC Volume. Goal is to retrigger the AHDSR with the Step lfo so that it constantly shoots the adsr pitch as well as shooting the volume gate.
I just cant figure out how to retrigger the AHDSR with the Step LFO in the matrix. Idk if im attaching things wrong or what but its a major part of this synth and i cant figure it out.
Plz help
Plz help
- Zayne-clone-trooper-synth-fsm-screenshot.png (44.59 KiB) Viewed 15828 times
ZAYNE
zayne - Posts: 24
Could you please post the schematic itself? Then we can offer help.
Cheers!
Cheers!
Spogg wrote:Could you please post the schematic itself? Then we can offer help.
Cheers!
okay hopefully it works
Clone trooper MINIGUN SYNTH Order 66.fsm- ZAYNE CLONE TROOPER SYNTH rough cut - Plz keep this lowkey
- (436.79 KiB) Downloaded 553 times
ZAYNE
zayne - Posts: 24
To trigger an envelope you need to set the envelope to Gate (in properties view) and supply a stream Boolean signal.
I’ve made a simple DSP which triggers the envelope when the Step sequencer output goes above zero. I set the matrix to control the pitch so you could hear the result. If adjacent bars on the step sequencer are set above zero you only get one env trigger until a zero bar is encountered.
Maybe this will give you an insight…
Clone trooper MINIGUN SYNTH Order 66 spogg dev 1 .fsm- FS 3.06
- (3.49 MiB) Downloaded 554 times
Spogg ur the fricken BEST !!!! Its working good now THANK U !!!!
Theres only one final problem...
The AHDSR only works if the Step LFO is on.
I turn up the OSC 2 vol Amp. and in the matrix only have AHDSR to Osc 2 Pitch. The AHDSR has no effect until u turn on the step LFO. Idk if there's a way to fix this but i still rly LOVE how it sounds right now!!!
ZAYNE
zayne - Posts: 24
You would need a selector for the env’s bool gate input to switch between the Step seq gate and the gate signal provided by the Voices to Poly prim. That way you choose one type of gating: Step or regular.
thanks Spogg !!!! i have a "automatic" and "single fire" mode now.
ZAYNE
zayne - Posts: 24
Everything was perfect but now theres a weird bug i cant fix. Whenever u adjust the Step LFO Smooth knob, the sound plays forever and wont stop. I rly like smoothing the Lfo for some presets so its important i need to fix this
Clone trooper MINIGUN SYNTH Order 69.fsm- (445.85 KiB) Downloaded 583 times
ZAYNE
zayne - Posts: 24
That’s down to the fact that when you set smoothing the output won’t drop to zero so it won’t retrigger the env gate when it goes up again.
You need to take an output from the step LFO before it gets smoothed and use that for the gate control.
