Preset management tutorial
Postby Spogg » Mon Nov 28, 2016 6:12 pm
Hi all
I was asked if I could put together a tutorial for the preset system since issues arise with folk from time to time.
This is my first attempt. It may have errors or need further clarification so please let me know. It includes a resource schematic.
No feedback will tell me it's perfect, which I doubt!
Preset tutorial v 1.21.zip
Updated 28.11.23
(227.89 KiB) Downloaded 527 times
Re: Preset management tutorial
Postby martinvicanek » Mon Nov 28, 2016 10:34 pm
Excellent! Goes right to my FS documentation folder. Loads of valuable information in there! :geek:
Many thanks, Spogg! :)
Postby Spogg » Sat Jun 03, 2017 11:57 am
I’ve reviewed the content of my tutorial and made a few changes:
I found that the Lock function can successfully be brought out on a switch for the user to decide.
I provided a modified Preset Manager module with this function. Tested in Reaper and it works as expected. The plugin user can now decide if any edits are saved when flicking between presets.
Main change was wrong information about changing the Preset Manager. The presets are not stored in the schematic as originally stated but “in” the preset manager itself. This is at the end of the document if you want to read it for more information.
Additionally I modified bits of text for clarification and corrected a couple of typos.
The new version is in the original post.
Postby k brown » Sun Jun 04, 2017 8:29 am
Thanks for that - it should help.
Postby RJHollins » Sun Jun 04, 2017 9:15 am
Thanks Spogg !
8-)
Postby adamszabo » Sun Jun 04, 2017 10:45 am
One thing to note is that in the 3.0.9 latest alphas a lot has changed regarding the preset handling. You can finally export .fxp and .fxb files if you want not only text. Also, the preset modules will now have an "Order" parameter where you can specify which order the parameters will be stored. That means if you add a new control later for an update, and you put its order to be higher than the last one, your old fxb and project and everything will still load properly.
adamszabo
Postby Spogg » Sun Jun 04, 2017 12:41 pm
Thanks Adam.
Does the "order" thing only refer to the FXP/FXB stuff? I can’t see that it will make a difference to the .txt system.
Or… ?
When we get a final release of 3.09 I’ll need to update the tutorial I guess.
Postby adamszabo » Sun Jun 04, 2017 2:10 pm
As far as I know the whole preset system was revised, so the order affects the parameter order inside the schematic, doenst matter if txt or fxp. Those are just two different formats you can save the presets as.
adamszabo
Postby tulamide » Sun Jun 04, 2017 2:45 pm
I wonder if we are allowed to talk about not just this, but all the new stuff, in public? I never asked, but normally developers prefer to get things done before announcing them?
Postby Spogg » Sun Jun 04, 2017 3:29 pm
tulamide wrote:I wonder if we are allowed to talk about not just this, but all the new stuff, in public? I never asked, but normally developers prefer to get things done before announcing them?
Yeah but that's normally :lol:
Seriously, I didn't get asked to sign a NDA or even keep it quiet and personally I think it will do a lot of good if folk see that good stuff is coming. I guess the worst that could happen is that someone might delay buying a licence until the next release.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 72 guests
