R&Rs wishlist for FS4
Yeah. I know i'm overdoing it with selectors/multiplexers. Buuut...
In the next FS4...
Can I have selectors and multiplexers with enumerator and a "2 part" connection indicator line, that is actually readable when selectors have lots of connections?
P-p-p-please Maik
In the next FS4...
P-p-p-please Maik
- R&R
Re: R&Rs wishlist for FS4
This would be a nice prim to have
...so as to avoid having to do this if using the regular droplist-prim:
Don't know if any MS standard dictates only one checked item per dropdown list as default though. Without having to write/manipulate that too to create new prim...
- R&R
This should really be posted to Discord in the suggestions section because it’ll be ignored if it’s here!
Sounds like a good idea... Can you help me repost these two there?
Since I'm not on Discord at the moment.
I'll ask for an invite if/when I come up with more...
- R&R
R&R wrote:Sounds like a good idea... Can you help me repost these two there?
I sent you an invite anyway and it’s one that doesn’t expire.
I think the suggestions should come from you directly so you can get replies appropriate to your ideas, otherwise I’d have to act as a go-between.
The discord server is much more active than this forum, so you can pick up general tips even if you don’t test FS4 yet.
Ok, have to check discord then...
- R&R
