Slower Largescope
• Page 2 of 3 • 1, 2, 3
Re: Slower Largescope
mmm-
I think we want to display 4 seconds at a time in the window.
It may involve writing to a mem, and turning that into a float array IMO
Something along these lines maybe?
audio logger.fsm- (27.04 KiB) Downloaded 992 times
martinvicanek wrote:Something along these lines maybe?
Thanks!!!
It is exactly what I was looking for!
- I also made a valid version, I simply added 2 primitive mono2graphs with 1 s delay (44100samples) to join them to create a larger and slower graphic. The bad thing about this is that it uses more CPU than it should ...
compressor_largescope_fixed.fsm- (601.3 KiB) Downloaded 1023 times
- Wassaka
Cool!
You could also join the mono2graph arrays using float array append.
Will a display like this ever sync to the audio visually ?
lalalandsynth - Posts: 600
lalalandsynth wrote:Will a display like this ever sync to the audio visually ?
Hi I made a largescope without scrolling and bpm synced, but it only works in FL version or Exported dll/VST Version. Not in standalone (This is because it needs information from the DAW). Is based on Martin Vicanek's Meter and it was modified by me, hope it works for you!!
- I created a HQ mode by default, if your computer is very slow, disable this option (This will change the tickrate and the samples to display).
Meter Tempo Synced.fsm- (572.17 KiB) Downloaded 963 times
- Wassaka
Excellent , trying this out ! Thanks!
Couple of questions : I need to resize it and make it work as an overlay .
How can I make sure a wave player is actually playing in sync with the tempo , that is , starting at the right point ?
It seems that even though I load a loop at the correct tempo ,it does not start at zero , or the beginning of a bar.
Am I making sense ?
I do not understand how you can make sure that the wave player is in sync with the tempo in FS ?
That is , having it play at the start of the bar in FS tempo for testing purposes.
Am I making sense ?
Last edited by lalalandsynth on Tue Jul 04, 2017 7:24 pm, edited 2 times in total.
Why this offset ? Could I make it start at the beginning ? I was having trouble with this so I just exported the scope as a VST for testing but it seems that a kick placed at the beginning shows up in the middle of the scope ?
- Offset.jpg (56.38 KiB) Viewed 25127 times
It also seems to creep in time . Set to 4 beats , envelope is set to 1/4.
Starts here .
And creeps to here and further given time , this was 1 minute.
PS: Still cannot get it to "sync" as in placing a kick at first downbeat and having it appear in the beginning of the window. Confused at this point.
Starts here .
