New simple GUI, Help needed:RUBY
Postby MANDANA » Tue Jul 11, 2017 2:56 am
I have create a new Graphic User Interface with two buttons. One that raises a value and one that lowers a value. My problem is that I don't know how to correctly code the ruby code found in the module. Can someone please send a ruby code that will work or explain how to fix the issue.
2 button GUI.fsm
(2.06 KiB) Downloaded 1141 times
MANDANA
Re: New simple GUI, Help needed
Postby lalalandsynth » Tue Jul 11, 2017 4:16 am
Do you prefer using ruby rather then greens ?
Its easy to do with greens.
lalalandsynth
Re: New simple GUI, Help needed:RUBY
Postby pshannon » Tue Jul 11, 2017 5:43 pm
MANDANA wrote:I have create a new Graphic User Interface with two buttons. One that raises a value and one that lowers a value. My problem is that I don't know how to correctly code the ruby code found in the module. Can someone please send a ruby code that will work or explain how to fix the issue.
Mandana,
I made a simple change, I hope this helps.
QuadBIT
2 button GUI quadbit fix 1.0.fsm
2 button gui up or down value fix.
(2.17 KiB) Downloaded 1209 times
pshannon
Postby MANDANA » Wed Jul 12, 2017 1:51 am
The project you sent me, pshannon, unfortunately will not load on my PC. Instead, a pop up that says (Flowstone requires a cpu that supports sse instructions, but my computer's CPU already supports sse). Then, another pop up comes up that says (Schematic load: type not found). Next, another pop up comes up and says (Could not create link inside module Button. Please report to the software support team). But I don't fell like emailing them so that's that. Finally after two dozens of clicks, the one last pop up comes up saying (Attempted to access an unnamed file past its end).
Geez, I've never seen so many different pop ups in my entire life. I hope the Devs see this post.
MANDANA
Postby RJHollins » Wed Jul 12, 2017 3:21 am
I had similar issue ... couldn't load it.
Postby lalalandsynth » Wed Jul 12, 2017 3:44 am
It is probably made in 3.09 beta ?
Stay away from that version , got burned :)
lalalandsynth
Postby Spogg » Wed Jul 12, 2017 7:10 am
Yes you get that oh-so-useful message storm if you try to load a 3.09 version into 3.08.
It's just a generic error meaning the file isn't compatible, for any reason.
I've sent a request for these early betas to be removed from download but it hasn't happened yet.
AVOID!!
Postby pshannon » Wed Jul 12, 2017 3:57 pm
Spogg wrote:Yes you get that oh-so-useful message storm if you try to load a 3.09 version into 3.08.
AVOID!!
Yes, guilty of the beta version, I will downgrade and resubmit.
pshannon
Postby pshannon » Wed Jul 12, 2017 5:18 pm
This sucks that I can't even open any of my projects with the step down version. I assumed that I could still open my projects if working with a minor version higher. So now, even my ruby code won't work! I guess I need to completely uninstall FS and reinstall. Not sure why I still work with FS sometimes. I know it is addicting, but the lack of company support is nonexistent from what I have seen for a very long time.
pshannon
Postby Spogg » Wed Jul 12, 2017 5:24 pm
You can try to copy and paste code from the 3.09 via Notepad into the code boxes in 3.081. I do know this works with DSP code at least, but not sure about Ruby.
