I solved my array copy/paste issue. Here it is.
Postby lalalandsynth » Mon Jul 24, 2017 2:05 am
So in my plugin I have 3 windows - switched gui's so only one open at a time.
In each window I have 4 parameters created with an array = an envelope.
I wanted to be able to copy from one array to the other.
I solved this but then I realised that I might want to copy from say parameter 1 in window 1 to parameter 4 in window 3.
So I needed to be able to copy an array from any of the 4 arrays in each window and to be able to paste it into any of the 4 arrays in each window.
I thought of using the int from the gui switching to route it , but that had problems , selectors and multiplexes hold their value so just switching a window would do a paste.
So I came up with this , pretty simple in the end....I hope ? Being a noob I might be missing a much easier way to do this and if so feel free to tell me :)
Array copy paste.fsm
(139.56 KiB) Downloaded 929 times
lalalandsynth
Re: I solved my array copy/paste issue. Here it is.
Postby Spogg » Mon Jul 24, 2017 7:45 am
Hey nice!
Well done Mr. Synth. :ugeek:
Postby lalalandsynth » Mon Jul 24, 2017 11:45 am
Thanks , I have yet to hook this up and see if I am missing something , but one module works so no reason to think that 3 will behave differently .
This could definitely be done with one Ruby window though :)
Now I am trying to think of a way to morph this into an undo . I might even just need one step of undo , just in case of a mistake when editing . Should be doable.
Need to find a way to have Ruby be one step behind in propagating a copy of the array , then just trigger that copy to go one step back.
lalalandsynth
Postby TeslaTronik » Mon Jul 24, 2017 12:51 pm
very nice
TeslaTronik
