How to make: Visual ping pong ball with sound or polyrithms
Hello,
dont you have idea how to create this exactly? (example video below) visual+sound, which software to use? Is it possible easily in Flowstone or you suggest some other software? (need it for one music visual project, thanks a lot)
Here is example:
https://www.facebook.com/reel/756111399756982
Here is example:
- mayo
Re: How to make: Visual ping pong ball with sound or polyrit
Thank God I'm not alone!. For several years I was obsessed with how to make a bouncing ball
in FS. I always failed, because you need to create some sort of physics engine.
A physics engine is my number one dream for FS, opening the door for some serious Game development.
I use software called "Fusion", is a perfect example of how a physics engine in FS should behave...with shitloads
of user control options. Right now I'm be happy with a box with a bouncing ball inside...any Guru's out there
looking for a challenge??
Thanks
Thanks
mayo wrote:Hello,
Here is example:
Exactly? No.
If you don't need the trail of past circles, it isn't difficult to do in Flowstone, though. Too much to explain in short, I'm afraid.
billv wrote:Thank God I'm not alone!. For several years I was obsessed with how to make a bouncing ball
in FS. I always failed, because you need to create some sort of physics engine.![]()
A physics engine is my number one dream for FS, opening the door for some serious Game development.![]()
Thanks
I did this once, at it isn't very difficult to be honest. First you set up gravity. It means a direction where the circle is pulled to contantly. For example to the bottom. Let's just set our gravity to 4 pixels per second.
You loop-call a method that applies 4 pixels per second (via deltatime) to the direction "bottom".
-method gravity
dt = t - time
t = time
circleforcebottom += 4 * dt
end method
With this alone, when placing a circle at the top of the screen, it will gain velocity and move gradually faster and faster towards the bottom.
Combine this with a "ground": an immovable object that will decelerate motion to zero, if no bouncing force exists. If it exists, you add the bouncing force to the circle, and it will accelerate towards the top, until the gravity moves it down again. Friction is defining the material of the "ground". When the circle moves on the ground, this is the amount by which it will slow down - it loses momentum. And lastly: angle of incident = angle of emergence. If the circle hits the "ground" at 30°, it will leave it at mirrored 30°. The curve it will take builds automatically from the applied gravity force.
And so on. Really, it isn't very difficult, once you start it. It is just very time consuming.
Love it when you explains things Tulamide !
Thanks.
Thanks.
tulamide wrote:billv wrote:Thank God I'm not alone!. For several years I was obsessed with how to make a bouncing ball
Thanks
-method gravity
dt = t - time
t = time
end method
Wow thank you, any chance you can post some example here?
Btw. I know way how to make some crazy money with this
if you want to cooperation
Thanks
- mayo
mayo wrote:any chance you can post some example here?
Yes... a working example would be great...as I still can't work it out...
I don't have the time to do it. But here's an interactive example. The code is on the right (Javascript - JS, very similar to Ruby)
https://codepen.io/AlexRA96/pen/egaxVV
tulamide wrote:The code is on the right (Javascript - JS, very similar to Ruby)
Thanks Tulamide ....I'm looking into it..
I found this online...might help
# Define the Ruby Component class
class BouncingBall < RubyComponent
# Initialize the component
def initialize
# Define instance variables for ball position and speed
@ball_x = 320
@ball_y = 240
@ball_speed_x = 5
@ball_speed_y = 5
@ball_radius = 20
# Update method to move the ball and handle collisions
def update
@ball_x += @ball_speed_x
@ball_y += @ball_speed_y
# Check for collision with window edges
if @ball_x + @ball_radius > getWidth || @ball_x - @ball_radius < 0
@ball_speed_x *= -1
if @ball_y + @ball_radius > getHeight || @ball_y - @ball_radius < 0
@ball_speed_y *= -1
# Draw method to draw the ball
def draw
fill_ellipse(@ball_x - @ball_radius, @ball_y - @ball_radius, @ball_radius * 2, @ball_radius * 2, "red")
Users browsing this forum: No registered users and 80 guests
