Flowstone 4 alpha (FS4)
Re: Flowstone 4 alpha (FS4)
don't cha just hate when that happens.
I've been in the process of adding several new hard drives to my computer.
So far have received 2 defective WD Black drives.
Also needed the special 'anti-vibration' harddrive mounting screws for my Lian-Li case.
Not a single US distributor has any.
Been all over EBay too.
Finally found on on-line store that had what looked to be correct ... having already waited on a shipment
from China [took nearly 2 months] ... but were not the right part.
Now, the new parts just arrived ......... from Slovenia.
And they screwed up the shipping label ... so I got to watch the 'tracker' move the package around the US
I've been dealing with a long case of Vertigo, and have issue bending over to lift my computer case to work on.
Had to hire in a Tech [$100/per visit] to do this simple install.
Will likely have to do this again to replace another 'new' drive.
Vertigo SUCKS
Vertigo SUCKS
After 16 years od dedicated service, my XP system has finaly been laid to rest.
I have upgraded my laptop and desktop, with win 10 and win 11 64-bit I also upgraded Reason
from 6.5 to Reason 12....a mind-blowing upgrade.
Did the whole thing for under $1000..
So you can all see the problem....all of a sudden FS is not compatible.
Can FS4 do 64 bit plugs??....should I get involved... I don't know in this state of confusion...
billv wrote:
... Can FS4 do 64 bit plugs??...
Yes, Fs4 alpha can create 32 bit and 64 bit plugins. My recently built PC is running Windows 11 and no problems with FS 3.06 or the alpha.
Great.. how do I get a copy?
billv wrote:Great.. how do I get a copy?
I sent you an invite.
I pressed the Google drive link today...so I'm waiting on a email. In the meantime, I have a few questions.
Where does it install.. in the 32 bit or 64 bit Program files??
If it's 32 bit, can I run 3.06 at the same time or do I have to un-install it??
Edit:
Well I got the download. There's no installer, so I can't install.
Clicking the application thumbnail yields error.
Edit:
billv wrote:I pressed the Google drive link today...so I'm waiting on a email. In the meantime, I have a few questions.
Edit:
Hi Billv
FS-4 is currently a 'Portable' app.
Just EXTRACT it into it's native Folder [so that everything is in one place [folder].
To Launch ... use Flowstone-64.exe
RJHollins wrote:To Launch ... use Flowstone-64.exe
billv wrote:Clicking the application thumbnail yields error.
The code execution cannot proceed because VCCMP1.DLL was not found.
billv wrote:The code execution cannot proceed because VCCMP1.DLL was not found.
Looks like one of the Visual C++ libraries...
Tried reinstalling https://www.microsoft.com/en-us/download/details.aspx?id=40784 ?
- R&R
R&R wrote:Looks like one of the Visual C++ libraries..
I downloaded and installed and it worked.
