FlowStone plugins compatibility
Postby User108 » Tue May 21, 2024 5:34 am
There's a great piece of software called VstBoard:
https://www.kvraudio.com/product/vstboard-by-ctrlbrk
It even supports scripting.
But unfortunately, any plugin I create with FS does not work in it, saying "error while loading plugin". Why is this and how can it be fixed? May be I place input |output devices wrong way? I tried many combinations - no luck. All other plugins load just fine. And FS plugins in FL Studio load just fine.
HiAsm - A Visual Programming IDE for ALL programming languages:
https://hiasm.com
User108
Re: FlowStone plugins compatibility
Postby tulamide » Tue May 21, 2024 7:58 am
User108 wrote:There's a great piece of software called VstBoard:
Flowstone creates standard VST files. If the host can't read them, you have to contact the developer of the host, to correct the error in the software.
Postby User108 » Tue May 21, 2024 8:20 am
But why that host reads other plugins just fine? I use Korg plugins as a reference plugins. That means something is missing in FS plugins, making them impossible to load. And as to "standart vst" - as far as I understand when FS exports VST, it actually exports FS runtime which then autoloads fsm schematics. Native VST plugins act differently.
https://hiasm.com
User108
Postby tulamide » Tue May 21, 2024 9:40 am
User108 wrote:But why that host reads other plugins just fine? I use Korg plugins as a reference plugins. That means something is missing in FS plugins, making them impossible to load. And as to "standart vst" - as far as I understand when FS exports VST, it actually exports FS runtime which then autoloads fsm schematics. Native VST plugins act differently.
I don't know, what else to say? You asked, I gave you the answer. You don't like the answer, but that's nothing I can change.
Maybe ask yourself this question: Why is it, that FS generated plugins run in every host out there, except this one?
When you have an answer to that question, the solution is close.
