Cross Correlation
1 post
Cross Correlation
This example shows how to use the Cross-Correlation module to correlate the time difference between two matching or similar signals.
In this case the slider simulates the delay between two signals, once the Test Now button is pressed a section of the two signals are sampled and the time difference is correlated.
The two times should match ie. the delay and the calculated delay.
Cross Correlation.fsm- Cross Correlation
- (28.28 KiB) Downloaded 2752 times
admin - Site Admin
1 post
Users browsing this forum: No registered users and 0 guests
